Just like the title says.  I tried the 1 1/2 motofab bottom spacer and it pushed the shock against the cv boot.  So I'm thinking I'll have to go with a top spacer, but can't seem to find a 1 1/2" top spacer.  Right now I have barely an 1" of rake in the truck, and think 2" may be a bit too much lift.  2" made my 18 look too high in the front at times.  So any help would be greatly appreciated.
Took my motofab 1.5 lowere spacer out right away after seeing how close it was. Hit on full droop. Try Rough Country leveling strut.
Worth to extra cash rides better the stock. My seem to settle at 1.5 . Also have a 1.25 block in rear.
Thanks.   Good info.
I went with the 1.75" top mount kit from Zone Offroad. I haven't installed it yet as I decided to swap out the upper control arms at the same time and just ordered some from Camburg.
Do you have a link?  I only see a 2” top mount spacer.  Please and thanks.
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
