I installed a can recommended by this site on my driver side. Does this create a problem on the passenger side? Do I need a can there or are the sides connected somehow?
Thank yoo.
Catch can captures crank case vented pressure. Both heads are connected by the block. My guess is the other valve cover doesn’t have a pcv port to feed back to the intake anyways. One can is all that is needed
I had the same question before I put my can on.  Some folks say it's fine....some say its not.  Mine has been running fine, clean TB, nasty can gases.  I think every argument for it is about efficiency and not function.
