What happened to the 2021 Silverado 1500 LTZ 5.3 being available with the 10 speed?
is that still the game plan or did that idea get scrapped?
GM is stupid when it comes to making widely available to its customers.
There are a couple of GM guys on here , hoping they chime in on why not.
Ford has the 10 speed across their entire line, even their base engine 3.3 gets the 10 speed now.
Probably can't get tooling done fast enough for supply to keep up with demand.
Today, order guide says:
MQB    Transmission, 10-speed automatic, electronically controlled with overdrive and tow/haul mode. Includes Cruise Grade Braking and Powertrain Grade Braking
WT and custom - not available
CustomTB -  Included and only available with (L87) 6.2L EcoTec3 V8 engine.
LT -  Included and only available with (LM2) Duramax 3.0L Turbo-Diesel I6 engine.
RST and LTZ -  Included and only available with (LM2) Duramax 3.0L Turbo-Diesel I6 engine or (L87) 6.2L EcoTec3 V8 engine.
LT TB - standard
HC-  Included and only available with 4WD models, (LM2) Duramax 3.0L Turbo-Diesel I6 engine or (L87) 6.2L EcoTec3 V8 engine.
Little disappointing the LTZ does not get the 10 speed standard. Another year of 3 different transmissions using
3 transmissions and 6 engines...
GMC/Chev is about trim differences.
SLT is comparable with LTZ.
On Sierra 10 speed is standard on AT4 and Denali.
On SLE and Elevation -  Available on 4WD models equipped with (L84) 5.3L EcoTec3 V8 engine. Included and available with (LM2) Duramax 3.0L Turbo-Diesel I6 engine.
On SLT -  Available on models equipped with (L84) 5.3L EcoTec3 V8 engine. Included and only available with (L87) 6.2L EcoTec3 V8 engine or (LM2) Duramax 3.0L Turbo-Diesel I6 engine.
Choices, choices, choices...
    erickn520
    erickn520
  • Who's Online   4 Members, 0 Anonymous, 1,490 Guests (See full list)
