Hi, I need 8 GDI injectors for a 2016, Sierra 1500, 5.3 NON flex fuel. The dealer said injectors 1,3 and 8 were bad, but best to replace all of them. That I agree with.
GM says I have 3 different injectors installed, low flow, normal flow, and high flow.
I read something from GM saying if the injector order were mixed up, the “normal flow” injector could be installed for all 8 injectors, but you could have fuel trim and emission problems.
With 4 injectors per bank, what injector do I need two of?
In what position does each injector go?
Are each injector banks the same?
GM Parts Giant.com has all 3 flows, new AC Delco injectors for $50 and $60.
Rock Auto does not have all three different injectors in stock.
I have read that a lot of people are having problems with their GDI’s.
The local GMC dealer mechanic said GM removed the GDIs from the 5 year/60K mike power train warranty and put them under the Bumper-to-Bumper 36K mile warranty.
He also verified what I knew about the fuel filter in the low-pressure fuel line, that is THE TRUCK DOES NOT HAVE ONE, DUH!!!
Anybody besides me think this is a problem?
I am sure most people on this site have changed fuel filters on their vehicles, BUT have you ever emptied the old filter into a clear glass jar? Even after a year you will NOT believe how much trash is in the filter.
For those of you who have a vehicle, trucks are easier, weather permitting on your next fuel filter change, will you empty the contents into a clean clear glass container. (A plastic soda bottle will work for a short time, but not recommended)? Then take and post the pictures?
I am seeing a Class Action Lawsuit. Is anybody else seeing it that way?
Thanks for any help, especially on the fuel injector placement in the rail.
Thank you, ZZsnowman
The injectors thing has been going on for awhile. I have probably changed a little over a 100 of them. I can say I have never seen different flow rate injectors in the same engine. Every injector I have pulled all 8 are the same and all 8 put back in are the same. I also have never seen a difference between the high, nominal, and low flow ones.
Sent from my SM-G975U1 using Tapatalk
I have never heard of different flow rate injectors on the same engine.
 Below is a link from GM TECH LINK, I got the impression it is an official GM site/posting.
https://gm-techlink.com/?p=13185
Also, I am attaching a link to GM Parts Giant online.
https://www.gmpartsgiant.com/parts-list/2016-gmc-sierra-1500_2wd/fuel_system_exhaust_emission_system/fuel_injector_rail.html
Any thoughts?  Thanks for any info.
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
