Hi all,
What are you guys using for reverse LED lights?
I installed some off-brand LED's from Amazon and they totally wash out the reverse camera screen, making it super bright inside the cab and basically blinding me from seeing out my side mirrors.
Thanks
On 12/13/2020 at 2:40 PM, MattyB4x4 said:
Hi all,
Thanks
Something similar to this? I’m not blinded but it does wash the screen out and you can barley see the guide lines.
I should have clarified - I just installed LED bulbs in the reverse lights on the truck. I do not have any aftermarket pods.
I guess I'm just looking for bulbs...or something that doesn't blind me.
I found that most of the "washing out" of the reverse camera at night was a result of the LED license plate lights I added. I have been meaning to replace them with the original halogen bulbs, but I have to find the housings (my led's were replacement housings). They LOOK great, but that much light aimed up at the tailgate where the camera is overwhelms the camera at night.
Take care,
George
Take care,
George
This [emoji1375] was what I was gonna ask. OP Did you also do the plate lights? I’ve changed every incandescent bulb I had over to LED EXCEPT the license plate ones and mine don’t wash out the rear cam at night.
    contrabombarde
    contrabombarde
  • Who's Online   2 Members, 0 Anonymous, 800 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
    • No, we trade them like pokeman cards.
