What leveling kits are you guys running? On my 2016, I just ran the 2.5 Motofab for the front with the RC Upper Control Arms. My problem is, I can’t seem to find control arms for 2020s without being 3” or higher. Curious on y'alls setups. I’m going to end up running 33s (A/T’s) on 22s.
I have a 1.5" procomp top mount strut spacer.  I installed it last week, and the truck now sits at 39 1/4 is on all four corners.  I tried the bottom spacer but it pushed the shock into the cv boot so I took it off and went with the top mount.
Edited by SILVER SLED
I got an LT with the motofab 2.5" in front and a 1" in block in the back.  I have factory control arms because Ive heard 3" and above is when you need different ones.
How have the factory control arms held up? Also, how much of a difference was the height from front to back without adding the 1" rear block?
It should be about level. I had a 2" lower strut kit from rough country and I also have a 1" block in the back. I was a .5" high in the back then i put the 2.5" upper strut kit from motofab but havent checked it since then.
Just installed the Fox CoilOver 2in kit. Rides pretty good but I had to put a block in the rear to give it some rake.
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
