i'm new to the forums , ive searched all over and cant find what im looking for
my truck is a 2015 silverado LT 1500
no idea what mirrors it had on it , someone installed towing mirrors and the functions would not work correctly
passenger would only go up and down when using the left to right arrows or vice versa
driver only goes up and down
the pins are not in the correct place for the towing mirrors
truck harness has 9 pins
mirrors have 9 pins
so i took all the pins out from the factory harness on the truck and started testing with voltmeter
but cant get them to work
anyone have a color diagram on the factory plug to see what does what ?
i just want the mirror to move up and down, and side to side for now
ill worry about the other features later on , ive read you have to add 3 wires to the harness or buy PGAMBOA harness
As far as the old mirrors, look in your glovebox at the RPO codes. Should be DL8 if you have an LT. PGamboa is def the man to get your mirrors working 100%. Do you know if they’re oem or aftermarket tow mirrors?
DL8 , I try sending phill a PM but either hes not accepting any or the system doesn't let me because i'm new
these definitely look aftermarket judging by the color of the wires
@pgamboa is a super busy man!  Lol. He’ll get back to you and get you all squared away when he gets a minute. I figured they were aftermarket by the sharply squared connector. If you get a chance, you might be able to unbolt the mirror and see if there’s any markings on the backside of the housing. I wouldn’t be surprised though if he could guess them by looking at the connector with his mental database.
I saw this thread earlier when it was posted, but been super slammed with orders.  This is most definitely an aftermarket mirror based on this wire colors, sleeving, and overall finish of the wire.  Can you explain the pink wire that is out?  Was it like this or did you do this?
The middle row of pins (5 pins total) are your circuits for - Mirror Heat (Pin #8), Mirror Motor Up/Down Control (Pin #9), Mirror Motor Left/Right Control (Pin #10), Ground (Pin #11), Driver Mirror Motor Common (Pin # 12).  The empty slot is position #7 which is not used (for mirror memory) in this mirror.
The top (can only see a red wire in your pic) and the bottom row (all empty), are usually the lighting circuits.
What I would do - is disconnect the passenger mirror and focus on driver only mirror first.  With the driver mirror only plugged in, what happens?  While you're at it, can you confirm the part # of the switch you are using?
Let's keep the troubleshooting here, so it will be visible to everyone.
I have seen aftermarket mirrors that have their motor wires flipped... so this will take some troubleshooting.
i broke the pink wire , rookie mistake , was going to re-pin the mirror harness and then saw everyone re-pining the truck harness , didn't know you had to lift the white tab on the plug , was doing it the old school way lifting the plastic tab next to the pin with a small tiny flat screw driver pulled to hard on the cable , no big deal , easy fix
on the mirror harness passenger side
pink = glass turn signal
blue = side cargo lamp
red = running light front of mirror
black i assume is the heated mirror or ground
on the truck harness passenger side
black i assume is heated or ground from what i read
green with black line  = mirror right
white wire =  left
yellow with brown line = UP
well i got it to work correctly , up down and side to side
and brown with orange stripe is the heating element +
now where do the other 3 go ? or what did they do on the DL8 ? i assume black goes with black ?
and the brown goes with the grey i have left in the middle row ? of the mirror harness
on the truck harness i have left
black with blue line
white with green line
blue with grey line
Edited by MIKE-HKS
Phil,
Are you still recommending Trail ridge mirrors?
Sent from my Pixel 3 using Tapatalk
Phil,
Been pretty solid mirrors.
    • Took me FIFTEEN MINUTES to find this. Isn't that a problem? On the mainstream media I can INSTANTLY find 100 articles bashing President Trump ... but when it comes to TRUTH in American corporate news & search engines, it's carefully filtered to support ONE SIDE. A Republic cannot survive like this! Incredible! Even all the AI searchers out there failed as well! ChatGPT said it needed more details on the video that I provided a DIRECT LINK to! I thought AI was the be-all, end-all?? I had to dig it up myself. This should be FRONT PAGE NEWS!!! 🤬   Here's the statement directly from our President:     Glenn Beck's reporting on the operation:   https://glennbeck.com/watch/videos/trump-just-revealed-a-massive-military-secret-that-lowered-gas-prices
    • More is cylinder deactivation. Kia-Hyundai Ive had 4. The warranty is the same 10 years 100K miles. My grandson drives the first one 05 Elantra GT. My wife drives the second one 2011 Genesis. The Genesis still performs as new and looks great. The Elantra looks rough. He’s not kind to it. The third was a Genesis coup. The fourth was a Santa Fe. Those were my daily drivers. I don’t keep them long. Kia is the same as Hyundai with the same warranty. I looked at the K-4 today. Too small, otherwise pretty good buy. Most of Hyundai and Kia’s have a performance upgrade.
    • Thanks for the point of reference
    • Great question. Answer....depends. One the volume of the crankcase, the driver that will actually be using the vehicle and the amount it uses plus the distance expected for that next trip. Couple of for instances:   Wife is going to drive Dizzy to Moline and back plus a bit around town so say 500 miles on the day. I know from years with that SUV that around town and local rural it uses about a quart in 1250 miles. But on the Interstate and her at the wheel without her anchor nagging her she'll push it and it will drop a quart in about 800 miles. Hence, around town I wait to somewhere between a quarter down to a quart down. On her trip I'd top it if it was down a few ounces and hope for the best.    Have I overfilled one? You mean by adding before it needs a full quart I assume. No, not once after finding the true fill mark.  I know the dipsticks of everything I drive and add what it needs. I learn this by doing the first oil change a quart low. Run the motor for a few minutes. Let it sit over night. Check and mark. Then add half a cup at a time making note of the place on the stick. I add through the dipstick tube with a barbeque basting bottle. Give it a few minutes to drain down and check again.    A vehicle like Dizzy that uses this much oil will take a few quarts between 3K changes. I keep one in the vehicle with the bottle and a bag. (Mindful of it's fullness) Not a big deal and never makes a mess of it. There is no such thing as "multiple quarts' in my shop for any specific oil. There will be a maximum however of the number of different oils used over the fleet.     Dizzy holds a nominal 5 quarts. So the first fill was indeed over as it actually took 4.75. My vehicles are fit with Valvomax valves so I can meter an ounce on the drain if need be. Found her mark first crack at it. Never to be repeated.    Pepper uses none between changes so I don't keep a quart in that one. Straight up 6 quarts put her dead on the full line. Check it ever fuel stop. They will surprise you when they start using.    Raven holds 3 liters or 5.44 ounces over three quarts. I add 3 quarts and 6 ounces. That gives me 5 oil changes on my orphan quart.    Lawnmower holds about 3/5 of a quart. I don't over fill it to prevent an orphan. So yea, depends.
    • 185k on original 6.2L engine and 10 speed. 6" lift with 35" tires. Changed oil (Mobil 1 synthetic) when truck told me to. Original tranny with original fluid and no service or flush done. All highway miles. A/C compressor replaced at 155k. Oil cooler line replaced at 180k. Still daily driver. Love this truck.   This is my 3rd 6.2L vehicle (2008 Yukon Denali / 2018 Cadillac Escalade) with over 150k miles and no issues. Denali had broken motor mount at 100k.
