ok I got my HPT up and running. stock settings, for fan operation is 210F across the cells on my 5.3 A6 truck.
i have the 175 t-stat. so i'm guessing 190 for fan activation should be a good start.. what do the tuners on here think?
Edited by flyingfool
i will try 195.
i also found it interesting there is a menu relating trans temp to fans , this might be good to play with for towing parameters
just curious but what kinda layout are you using for your desired ECT vs coolant temp?
why do the numbers start so high on this table, there is no adjustments below 192F?
update here..., found i need to upgrade to a 2 bar OS to get more adjustability
https://forum.hptuners.com/showthread.php?7621-LS2-Fan-Logic-or-lack-thereof&highlight=LS2 fans
so all we got are 2 cells to adjust, 192 and 210. lol...
This is what I used:
Edited by UnlimitedMatt
you use 15 for the first row, I've seen others use 50 for the first row... I will give it a shot.
what have you set the fans for on trans temp activation?
tomorrow is disabling TCC,  shut off 1-4th gears .
I you haven't changed Fuel>Power Enrich>Throttle>Enable Pedal
From the factory it's set to not go into Power Enrichment until 89% throttle.  I would lower that.  I can show you how I have mine if you want.
And same screen under Delay>RPM Factory is 5,000 rpms have to be met before Power Enrichment is added.
So from the factory you have to be above 5,000 rpms and over 89% throttle input before the ECU gives you the extra fuel to go WOT.
53 minutes ago, flyingfool said:
please show me your set up..otherwise upload the HPT file and i'll check it out
I’ll post a screen shot of it in the morning
  • Thanks 1
Any lower than this can cause a fuel dump situation and creat alot of black smoke on the hit when going WOT.  Or at least it did on my truck.  I'm pretty new to tuning but I feel lke I'm picking it up pretty well.  Ask any question you want.
Edited by JONBLARC7
i would like to find out if its possible to activate V4 DoD mode at a certain speed range like highway speed only. I dont want v4 when in stop and go traffic but i do want to drive in 6th gear around town
i'll try it out tomorrow
I wouldn’t change the EQ ratio until you have a wideband.  You can get good gains with part throttle tuning using your STFT and LTFT.  Just tune your fuel before you go into power enrichment.
Read your tune file, it tells you right there what speed you can enable or disable AFM/DoD.
If you don't want it on until 50mph, then put 50mph in the MIN VSS box.
On the PE stuff I change the EQ ratio without a wideband on stuff all the time. Just don't go asking for 13.0 AFR if you can't watch the fueling with a wideband oxygen sensor. Stick to 12.2-12.5 and it will be pretty darn close if closed loop fuel trims are showing good and there is no mechanical issues.
  • Thanks 1
i found it, got it programmed to 50mph.  I'm not ready to play with the fueling. I want to get the transmission dialed in better, feeling better everytime i tweak it.  this sure beats pulling valve bodies and gov weights ..
    appletrav
    appletrav
  • Who's Online   4 Members, 0 Anonymous, 294 Guests (See full list)
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
