With only 7,200 mi, my new truck is at the dealer service center right now because there was a rear main seal failure, and massive oil leak. How in the heck could this happen to a new car?
Edited by winnemucca
Greed, basically. Automakers don't care about longevity - they want you back in the showroom as soon as possible. In their quest to save a few pennies on a part, sometimes they go too far, as with the AFM lifters, low tension piston rings, valve springs, the 3/4 clutch pack in the old 4-speed trannys, spider gears in the rear differential (and probably the front, too), rust prone body panels and undercarriage parts, ball joints, shocks, brakes,  and the list goes on ...
Sounds like they cut too many corners on that rear main seal ...
Edited by Jsdirt
Unfortunately, at today's GM, quality seems to be job none.  Consumer Reports just rated ALL of the new Silverados/Sierras/Colorados/Canyons in their "don't buy" category due to poor reliability.  Good luck.
Edited by MaverickZ71
Contrary to what has been posted, vehicles today are far better build quality than days gone by.  I have bought new cars in the 70s, the 80s, the 90s, the 00s and the 10s.  Everyone of those vehicles went back to the dealer for warranty repairs except the last one.  Its been 10 years since I took delivery, and other than the rear window being replaced due to missing parts of the heated window strips that was noticed before I left the lot.  First vehicle to not require front rotors in the first 20k, actually been 10 years, still have original rotors.
There is a reason they put warranty on new vehicles.  Sometimes there is a defective part.  ****** happens.
I think everyone in MA needs to find your car dealer, Doug! Not a single person I know, family or not, has had any luck with anything built after '96, and even less luck with stuff 2007 and newer. Not just cars, but refrigerators, snowblowers, lawn tractors - everything ...
You wouldn't believe the stuff I see every day. The older stuff is always running longer, so long as the owner keeps the vehicle oiled to keep it from rusting away to nothing.
Edited by Jsdirt
I have a friend that is a retired GM employee, he bought a 04 Sierra SLT Ext cab in late 03, dealer had the factory ordered truck in under 2 weeks(helps that we are 10 miles from Oshawa plant), his only warrantee claim was an o2 sensor that failed as he was going through a car wash.  He also had his ignition key replaced because the plastic/rubbery part broke where the ring when through.  Then came my truck, then he bought a 2012 SLT 4x4 4 door along with his son getting a 2012 SLE 4x4 ext cab.  His son's truck had to have the leaf springs replaced due to one leaf breaking, outside of warranty.  He used his 04 truck to tow an enclosed trailer for motorcycle track days.  No warranty issues, and no transmission issues.  My last 4 new cars where in the 2000 and onward era, they all needed front rotors before 20k.  I live in the Canadian rust belt.  It may help that both him and I are licensed auto mechanics(we met working at a Chrysler dealership nearly 40 years ago).
I get what you are saying about the stuff you see every day.  You have to remember that you don't see the cars that don't have issues, and I will guarantee there are millions more that you don't see.  Your reasoning was exactly the reason I bought a new Mustang in 78 while working at a Plymouth/Chrysler dealership as a transmission mechanic, every Plymouth I saw was broken, never saw a good one.
  • 1 month later...
Curious what the outcome was here. My 2020 GMC Sierra Denali Diesel also just blew rear main seal at 4000 miles. Have had the truck for less than 60 days. The service advisor also told me they had another one exactly like mine come in right behind mine. Has yours been fully repaired? Was it just a bad part or something else that cause the failure?
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
