Gents - Newbie here to the forum scene ...
  I saw a thread about someone asking if anyone had done any kind of swap or mod for the sun visors to get lights as my TB does not have visor lights. I’d rather try to swap the visors for the HC visors, which have lights, rather than do some mod or something shitty.
  I popped off the drivers side visor, but no wire was there. Could it be above the headliner somewhere?  I’m thinking it’s gotta be, but curious if anyone else found it, by chance?
  I swapped my rear view mirror for the auto-dimming one, which was easy, thanks to the thread on this forum about how to do it, so I’m hoping to find the same information for the sun visors.
  If there has already been a discussion / solution to this, & if someone doesn’t mind, can you point me in the right direction?
  Thanks!
  • 1 month later...
Has anyone been able to figure this out? I have a 2020 Silverado LT crew cab. I’d like to replace the current standard sun visor with one that has vanity lights. I’m wondering if there is an existing power source to just plug and play with an upgraded visor with vanity lights.
  • 6 months later...
Not hard.
2021 Trailboss.
When doing the suggested rear view mirror replacement, might as well do this at the same time.
There is no prewire..but super easy to fish some 18 gauge speaker wire or ???? over to the center overhead console  (that you have down already when doing the mirror) from each side.
Cut the connectors off each visor, make nice shrink wrapped connections to the above wires on each side.
Then at that center console is a connector for the sunroof, you can tap or use female spades if you have no sunroof.
Easy peasy.
The vanity lights are LEDs, so polarization is important. Red + Black -
Visor part numbers..yes they match all the Trailboss headliners:
84637521 Sunshade Sun Visor RH Dark Gray Lighted 2019-20 Silverado Sierra 1500
84637498 Sunshade Sun Visor LH Dark Ash Gray Lighted 19-20 Silverado Sierra 1500
There is a different wiring harness from the factory.  If you chose to go this route you'd have to drop the entire headliner.  Otherwise, try splicing in like one of the posts above describes.
  • 1 month later...
On 9/23/2021 at 2:22 AM, Trailbossboss said:
Not hard.
2021 Trailboss.
Easy peasy.
Is the switch already in the visor? Yes there is constant 12V in the overhead console, but how would u turn it off?
  • 1 month later...
On 9/23/2021 at 3:22 AM, Trailbossboss said:
Not hard.
2021 Trailboss.
Easy peasy.
I wonder if 84711898 or 84711896 would work for a factory wiring solution rather than tapping connections?
  • 1 month later...
Anyone know if the visor will fit 2021 model, the part # only  lists fitment for 2019.
  • 3 years later...
im.looking to do the same.with my 21.silverado. Was hoping there was a conector alrdy or wires u.could throw.an end on. The passenger side does not have a vanity light. Do they sell a small wiring harness or anything?
Could u just take 16 or 18ga wire and route it over to the drivers side mirro with light alrdy there and splice into it??
Edited by Football08
The wires are there above the headliner. I swapped the ones in my 2021 Trail Boss Custom for lighted ones I found on ebay. Direct plug in. I also found an OEM auto dim mirror for my truck on ebay and found the plug glued to the roof and was a direct plug in.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,260 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
