I got told my throttle body in my 2017 is failing and throwing codes. Has anyone upgraded throttle body on a stock truck? Any good options out there to fix it and maybe get alittle more "juice" out of their truck?
Anything helps thanks!!
If youve got an L83 you could upgrade to the l86 tb and im i did this before putting my turbo on and saw noticeable performance especially im bottom end and throttle response but if youve already got an L86 youre only other gm option is the LT5 tb which requires an adapter plate to be installed. If youve still got the l83 intake manifold i doubt youll see any major improvements in performance until you upgrade to at least the l86 im. Any of these will require an adjustment to your tune too btw.
I got a Soler Performance TB on my L86 and I thought it added a nice improvement from stock.
The biggest they have is a 95mm which is equivalent to the LT5 throttle body. I assume you wouldnt buy an 87mm because thats what comes on the l86.
Soler performance 95mm=$335
Gm ac delco 95mm=$195
I did this one:
SE8223-040, 87 MM (91 MM EFF.) - $275 now, I think I got a discount/sale price. Don't recall.
20 minutes ago, ftwhite said:
I did this one:
For that price he could just get the lt5 tb tho thats what id recommend it would be a gain of 3/8” from stock as opposed to 3/16” with the 91
$195 for a LT5 TB + $70 for the adapter plate to fit a L86 intake? Yeah, that saves some money, I guess.
Assuming he is starting with the L86 intake, or upgrading to one, at least.
I'll have to add headers and CAI on mine first (coming) before getting my brain wrapped on 95mm vs 91mm.
without a doubt too close to make a big fuss over i would literally go with whichever is cheaper honestly. If hes putting it on an l83 either one would provide noticable improvement
bigger is better, since the factory tb programming wont open them past 80-84% at WOT unless you got the 6.2 software or 6.2 equipt truck.
Edited by flyingfool
I think this is only true if you're making more power than the factory driver demand tables can accommodate. For example, if I'm making 100 HP more than stock thanks to a blower, the higher pedal position rows will become a limiting factor.
That's all TQ MGMT is these days. Log TQ MGMT advance and it will tell you more about what's going on. (ignore TMA - tq mgmt advance - during shifts as that's there to make the shift smoother and faster.
8 hours ago, flyingfool said:
I'll look into that. but at stock power my last log showed 84% tb opening
For whatever reason there's a half dozen different PIDs related to pedal position and throttle position. I seem to remember reading about one of them that always displays 84%.
    • It's possible the two trucks are using different body control modules which is why yours works and the OP's doesn't.   So much in these newer vehicles depends on model/trim configurations, production date. They don't all use the same modules like back in the day.
    • I forgot to answer the question as per what market mine is set to and yes I finally found that area on mine and yes its also set to America.   So here's something I realized as I wasn't looking at that part in the Sierra section until now, your right that what I see here as choice 3 under Sierra which says 07/2023-06/2026 ( 433 MHz 13542523 ) it has no choice 5 for tire pressure selection. Where as it does under the Chev choice. However I kept going down the list within the Sierra and I am really wondering if choice 9 will work for your truck as it has the same model number and hertz sensor as my truck. I would say try that choice first, if that doesn't work then jump over to the Chev section and again choose that same model and hertz choice as for some reason the Chev section gives the choice 5 of tire type/pressure selection for going back a number of years. Could very well be an Autel thing that they just didn't get the updates all done properly under Sierra but anyway first try that selection 9 I suggested under Sierra and then go from there.
    • Looking for this piece that holds the hose clamp in place. I have the hose clamp just not that other piece. Dealers and wrecking yards in my area will not sell just that piece. They want you to buy the whole air tube $100 +/- to get that $5 part.  that piece isn't molded to the air tube as I looked at my friends truck. It's held on by a screw and nut. I'm trying to put the OEM parts on the truck as the previous owner butchered things up installing an aftermarket CAI. It really looked homemade. 🤣 Thanks
    • Ok I missed that part that yours is a GM. The strange part is that the choice for year ranges and within the year of 2026 is different on the Sierra then on the Chev for some reason as I am looking at my tool at the Sierra choices. Now I am guessing you see as to your sensor part number as it may be different on your truck for some reason and a call to GM should get you the part model number of the sensors you should have as well as which MHz your sensors are. I know mine are the ones as per what I listed but there are other choices in the Autel and got me wondering if by some chance they put different ones in your truck. Having said that, did you try using each of the choices starting from No 1 and going on down the list, not sure if that would mean shutting off the engine each time and resetting the tool and going at it again each time. Also I thought of something else which may sound retarded but if there was some stupid chance that the chev choice would work. The reason I say that is that the Sierra is showing a range up to 06/2026 for the various choices of sensors it could be where as the Chev has one choice that has that 12/2026. By the way it is possible to not run the truck and you may know that as per not pressing the brake but pressing and holding the start button for a few seconds and it lights up the dash ( its called service mode ) but that sucks battery power and if it were me doing it that way I would be throwing on a decent sized battery charger before doing it that way as killing your battery won't make you happy at me at all !.    Like I say, just a thought to try the Chev choices if you have already exhausted the Sierra choices but first it would be nice to know for sure what exact sensor model and hertz your truck uses as I assume only those choices that mention the sensor would work unless a choice that does not mention the sensor model would somehow work. Its frustrating when one is trying to use tools like this without the experience of the tool and the vehicle, as I am sure dealer techs themselves struggle with it when starting out or a new model year comes along that is slightly different.
    • I tried before I updated the scan tool just incase an update messed it up, but it never worked so I updated the scan tool and it still didn't work.   Only difference is I click on Sierra not Chevrolet cause I have a Sierra.   If I click on 2026-2024 I didn't have any option to change placard, when I click on 2023 it does give me the option but when I try to do it,.it says vehicle not supported!   I have my region or market or whatever it is set to America I think, is that what yours is set to?
