What Power Steering Fluid are you guys running in your 6.0 Gassers? I was wanting to flush and run a good synthetic. See below on the compatibility responses from Amsoil and Redline.
Amsoil:
"Unfortunately, we do not offer a power steering fluid for this vehicle.  Our Power Steering Fluid (PSF) will not satisfy the specification requirements that GM wants for this truck"
Redline:
Thank you for contacting Red Line Oil, the PowerSteering fluid would be compatible with those fluids, though they are ATF based and our D4ATF would be the recommended replacement.
I read the Royal Purple is a good one and it says its compatible with all OEM fluids. I am not against the OEM just was wanting a higher quality fluid. Is GM # 19329450/ AC Delco# 10-5074 the current P/N? When I looked up the AC Delco # on their website, my year is not on the vehicle list. Very strange.
Edited by Abominator
Still using dexron vi havent looked into the difference of other brands but this should be pretty close to the best fluid for our trucks
Sent from my Pixel 4 XL using Tapatalk
The quart bottle is 19329448, pint is the 19329450.  Both are current #s.  GM does not list Dexron 6 or any ATF as an approved fluid for the power steering in the HD.
