What Power Steering Fluid are you guys running in your 6.0 Gassers? I was wanting to flush and run a good synthetic. See below on the compatibility responses from Amsoil and Redline.
Amsoil:
"Unfortunately, we do not offer a power steering fluid for this vehicle.  Our Power Steering Fluid (PSF) will not satisfy the specification requirements that GM wants for this truck"
Redline:
Thank you for contacting Red Line Oil, the PowerSteering fluid would be compatible with those fluids, though they are ATF based and our D4ATF would be the recommended replacement.
I read the Royal Purple is a good one and it says its compatible with all OEM fluids. I am not against the OEM just was wanting a higher quality fluid. Is GM # 19329450/ AC Delco# 10-5074 the current P/N? When I looked up the AC Delco # on their website, my year is not on the vehicle list. Very strange.
Edited by Abominator
Still using dexron vi havent looked into the difference of other brands but this should be pretty close to the best fluid for our trucks
Sent from my Pixel 4 XL using Tapatalk
The quart bottle is 19329448, pint is the 19329450.  Both are current #s.  GM does not list Dexron 6 or any ATF as an approved fluid for the power steering in the HD.
    goetzmann
    goetzmann
  • Who's Online   5 Members, 1 Anonymous, 561 Guests (See full list)
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
    • Desirable - as in does someone WANT one, aspire to have one. Could reasonably buy any car they want and CHOOSE these instead.    I didn't watch the video, why did they win?
    • The use of absolutes like "always" to describe gear selection, and giving free advice at a boat ramp sounds like a recipe for disaster. It's a boat ramp, not a farm, for starters.   IMO gear selection should depend on the obstacle. If low range is working and this is a slower speed, controlled ordeal, I'd keep using that.
