I've been trying to install the OEM front and rear splash guards for about 3 weeks. I've went through several different ones from the dealer. They keep saying they are the correct ones but they never line up correctly (see the pictures). The only part that lines up is the 2 screws that you have to remove to install.
Has anyone had this issue? Is this the correct rear part number?
1 hour ago, dennismc said:
For GMC Sierras the front are 84420655 and the rear are 84420656.
Mine is a Silverado.
Edited by mjonesjr84
It’s correct.   That top plastic piece needs to be folded onto itself so it clamps to the wheel well.  So 4 holes become 2.
I get that, but the holes do not even line up to the bedside where it is supposed to be drilled.
I shouldn't have to drill new holes in the splash guard. That'd stand out like a sore thumb.
Does it just clamp on the flange of the fender?
Fold over part make it so it can't move outward (the edge of the fold-over pushes in the inside of the fender. hidden by the flange, while the portion on the outside of the fender keeps the guard from moving inboard.
No-drill so not adding a new location for rust to start in visible location.
Edited by redwngr
No-drill so not adding a new location for rust to start.
No, you have to drill the bedside and add a couple rivets (3). The bedsides are aluminum so no rust issues.
19 minutes ago, mjonesjr84 said:
There is plenty where hole A is. Did you look at the picture? Holes E & D per your instructions and my picture are not on any metal.
Holes E and D don’t require metal.  The plastics folds onto itself and E and D screws into themselves once folded.
Edit:  And yes, I did look at your picture.  Just trying to help.
Edited by SilveradoRST
Yes, once folded the plastic just clamps onto the flange of the fender/wheel well.  No metal or drilling required for holes D and E.
The instructions you posted as well as the ones I have say "Drill Here" and show rivets going into the holes on holes D & E in Figure 3. Why would you have to drill if you were not going into the bedside? The holes line up when you turn over the tab.
Do you have a set of these installed on your truck? If so, can you post a picture of how holes D & E are?
3 minutes ago, SilveradoRST said:
That's exactly what I needed to see. Did you install these or were they installed at the factory?
I would have thought that they would have went through the bedside.
    • I would be surprised if the diff's were not filled (with the cheapest gear lube) at the axle factory before being shipped to GM.  If you ever watched them building trucks they install the axles and all suspension parts with the frame upside down and then turn it over before its time to install the engine.     Too much gear lube in a axle can be worse than not enough especially with a lower quality GL where is get whipped up with entrained air (foam)  weakening its ability to lubricate.
    • This is the 6.6 gasser section of the forum, you should either delete or modify your previous post as it is misleading for anyone looking for factual information on their 6.6 gas engine.
    • Well....I've done my first intake gasket. Probably wrong, but...we'll see?   Ultra black on the china walls and 1/4" up onto the sides of the intake gaskets. Permatex High Tack (couldn't find Gaskachinch) on the head side of the intake gasket. I read wrong and it says you're supposed to put it on the mating surface of the head, not the gasket. Hoping it's like a PB&J sandwich where it doesn't matter what side the PB goes on so long as there's jelly. That crap is messy/sticky and I got a dab or two on the intake port openings, tried to wipe it off. Hopefully it won't be a big deal and will only aid in sealing.   Per instructions I left the intake (top side) of the gasket dry except for a light smear of RTV around the coolant ports. Wiggling the intake in there was a bear but I had help to free me of surrounding wiring/stuff but I was basically able to set it straight down lined up with the bolt holes.   I did not think to wait until the RTV skinned over but there probably was 5-10 minutes while it sat before installing the intake.   Bolts finger tight first. Then, followed the Chilton's manual pattern to snug them to 15 lb-ft.   Waited a little over an hour, and then did the final torque in sequence again to 35 lb-ft.   Yesterday I replaced the fuel pressure regulator and got my new "nut and bolt kit" (fuel lines) installed. Damn GM used security torx on the spider, which I don't have, so I got scammed at the local HW store for an off-brand security Torx bit set.   The new driver's door mirror arrived yesterday, so, there's a chance this thing could be running and road legal tomorrow? I don't want to get my hopes up.   This will be my first time stabbing a distributor, too. Although, lucky me, someone else marked the old distributor for removal previously, I did see that. (Someone's been here before!!). Engine is still at TDC so it *should* be just a matter of transferring the mark to the new dizzy and rotating it into place.
    • He has his dad’s newer truck he’s put away. He has several old cars he rotates between him and his family. I’ve seen a restored square body and a SS Chevy truck he’s sometimes drives. He did raffle off a new suburban recently. As much as he is watched if he drove new stuff as a rule we’d know it. It would be fine by me. I don’t care what people prefer. I got one more new one in me. I’d rather my wife get one. I can’t get her out of the Genesis. Don’t tell anyone. I want her to get an electric truck. I want to put a generator in the back. Just because. She hasn’t bit yet.
    • Yes, you must have seen my thread on the Blazer. HOT GARBAGE, but I love them anyway. I'm convinced every car guy has a soft sport for an S/T series somewheres. Probably even a Panther too, if I'm being an honest car guy. That doesn't mean they aren't junk. And they definitely don't get better with age. I sometimes play with old cars, but that's by choice. I don't rely on them and they aren't my everyday fleet.   Derek plays the common man on Youtube and that's no doubt where he started. Now he has Youtube money (and Motortrend, etc). You think his crews and his wife ride around in old beaters when they're chasing him and his wrecks across the country? No he's got newer and nicer stuff for that, you'll see glimpses of it in the footage.
