Looking to either level or lift my 2021 HD LTZ
Not looking for anything huge as far as lift....
would like to run 35x12.50x20s...-18 offset wheels maybe
whats a good level kit our there or reasonable lift kit to fit this combo????
I'm thinking the same way. Although a tad pricy I think I'm going for a BDS because of the warranty it offers. I'm not interested in blocks, pucks or other light duty junk.
Thinking the BDS 3" or 5" to run a decent 35" tread offroad with no rubbing...
Don’t bother with leaving kit.
every shop I went to said that everyone that put a leveling kit on there 2500 hates it to either leave it as is and just put bigger tires if you want that can fit or put an actual suspension lift kit. One of the shops straight up just said they wouldn’t even do leveling kit on 2500s that it was just a waste of time and money.
I went with the FabTech 6″ RTS LIFT KIT W/ FRONT DIRT LOGIC 2.25 RESI SHOCKS & REAR DIRT LOGIC 2.25 SHOCKS – K1160DL.  With 37s Everybody kept giving me different ones to get and what they thought was best but when I talk to the shops that actually knew what they were doing they would ask me what my application was and how was going to be using my truck.  I’m on the freeway most of the time, off road in areas that I need high clearance(for fun and for work at times)25-30% of the time , and I tow a 32 foot travel trailer once or twice a month.
There are other brands of people said we’re better than fab tech but when it came down to it all things considered the fab tech was the best fit for me.  They actually have a good ground clearance and keep the torsion bars tucked away unlike others that claim to have high clearance but have the torsion bars sticking down way out.
I retained my towing and hauling capabilities from stock and the ride seems better.
Are those 18" or 20" wheels?
Looks great!
Looks great!
Thanks!!
they are 18s
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
