Has anybody found a way to tighten up the rear view camera mirror in these trucks? If i switch mine from mirror to camera mode it moves a bunch and then i have to readjust its positioning every time. It also shakes whenever the music is playing.
Mine doesn't wiggle/move around.
I've had this truck for about 3 months.  I hadn't used the camera mirror.
Quite by coincidence when I was out yesterday I remembered about it and gave it a try.
All 3 settings were not to my liking, but especially the the camera up/down and the zoom. (at first I was gonna adjust the position of the mirror, but then recalled the camera adjustments)
 I'll give it a longer try,  but so far not not sure if I'll switch to usually running the camera or stick with the 'normal' mirror.
I have it in camera mode full-time.  No shakes, on bumpy roads or music.  It is so tight, I use two hands to adjust it, cause it felt like it was going to snap off if I tried to force it/move it with one hand.
I know there’s a way, but how, not sure. After the dealer dropped my headliner to fix the window leak, my mirror was extremely loose when they gave it back. I took it back and now it’s tight.
Probably something that can be done DIY. I had all that plastic around the mirror off when I installed my radar detector, it comes apart easy.
Use a trim tool to remove the plastic center trim piece that surrounds the mirror.  There is a torx screw that can be tightened.  When the dealer did my headliner they did not tighten the mirror all the way.  The tech came outside and 5 minutes latter it was done.
Awesome. I’ll check that out too. Thanks!
    Charly
    Charly
  • Who's Online   3 Members, 0 Anonymous, 3,703 Guests (See full list)
