I'm curious if this generation of Chevy Silverado's (K2XX), mine is a 2017, have grease fittings for the steering components? My last truck, a '96 Z71, did have grease fitting on upper & lower ball joints, the steering pivot areas and the front drive shafts spline area. I could not find anything in the owners manual except "grease if it has fittings". Any help on this? I use to try doing it at least yearly on the '96.
The only ones I have found are the outer tie rod ends.
Correct. Those are the only grease zerks I have found on my 2018 Sierra 1500
You can always drill, tap, and add Zercs for a lifetime of serviceability.  I just did this on all the new ball joints and tie rod ends for my '70 Beetle when I rebuilt the front beam.
    erickn520
    erickn520
  • Who's Online   3 Members, 0 Anonymous, 559 Guests (See full list)
