I'll get right to it. I keep an eye on my trans fluid temp, and about a week ago I noticed my temps going past 210°. I was seeing 235°-237° consistently. I brought it to a trusted dealership and they confirmed a cold trans return line. Fluid was dirty and the flush machine confirmed some blockage. So the dealership flushed until the flow was within spec, replaced fluid and filter and I was on my way. The trans temp got up to 234° on my way home testing it out. What're y'alls thoughts? I'm friends with the tech that worked on it and he seems to believe I might have a torque converter issue. Thanks in advance for the help and advice.
If you haven't flip the pill in the transline, then you need to. I wouldn't have flushed any thing and instead just changed the fluid and a new set of lines. Flush would have been my last step. Hopefully you get it worked out.
Sent from my SM-G975U1 using Tapatalk
  • Thanks 2
Seems like the inline thermostat isn't doing it's job.
I agree with the above, do the thermostat mod and see if things get better.
  • Thanks 1
If you have found debris it's likely the clutch pack wearing or tq guts. Id side more to clutch packs tho from the sounds of it. Any other issues to be noted?
The tech said that he didn't notice any metal shavings in the oil pan. The trans operation has been very consistent through this all except for a one minute duration of going through town. At about 25 mph it didn't want to shift down. Other than that the trans has been acting as normal. It has always had a slight slip here and there when going into third gear.
I've always thought a flush was a last resort, but it's what the dealership wanted to do and I know nothing about trans. I saw a few videos about the delete and that is very doable. I think I saw that the new lines come with a new thermostat? I might start with the thermo delete and go from there. If anything I will do a de-grease, brake cleaner/air compressor clean out of those lines unless it isn't advised. Thank you!
Yeah man I'd bet clutch packs for sure. Ugh that sucks dude. That's where the slip comes from
What exactly does flip the pill mean? Am I literally flipping part of the thermostat, or am I removing the springs etc.?
Skip to the 3 minute mark of this video, this is all you need to do. He is replacing the whole assembly but you only need to remove the thermostat block from the transmission and lines.
Thank you very much for the reply. So I ended up finding a similar video and got my "pill flipped". Everything is back together and my trans now runs between 135°-150°. Thank you all for your suggestions. Sometimes I forget how helpful this forum can be. ??
  • Like 3
Do you take the whole assembly or did you take off the block and do it under the truck and put it back on? And it you took it completely out did alot of fluid leak out?
You take the thermostat housing right off. I would say about one ounce of fluid comes out. It requires a 13mm wrench or socket, pliers, and a good snap ring tool. I used the the interchangeable snap ring head to remove the C clips for the cooler lines. A pick would have been better suited. I brought the thermostat inside to do the flip as it can be a little easier than under the truck haha
  • Thanks 1
Thanks for the info and I have the tools and I'll just have to do it next weekend.
Your transmission will have much lower temperatures. I took my truck on 300 mile round trip last Thursday to pick up a rear axle for my DD. 150 miles ups the interstate running 70-75 MPH. Temp never got above 145.
I've been running delete for a few years now.
Purrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr.
:driving:
    Whit.the.COB
    Whit.the.COB
  • Who's Online   0 Members, 0 Anonymous, 1,137 Guests (See full list)
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
