For those with the multipro tailgate, has anyone sprayed their tailgate? I like to err on the side of engineers being smart and doing things for a reason...trying to understand why it isn’t sprayed and just a plastic cover protector
that plastic cover is the tailgate am pretty sure, not sure there is sheet metal underneath.......my 2500 didnt have plastic it just had sheet metal......and believe my 19 RST just had the plastic cover with no sheet metal under it.....am not 100% positive but remember either reading it or hearing it......could be 100% BS of course
which is actually nice cuz replacements arent expensive and can be eaily done if it gets messed up and mine surely will
Edited by Dunn
When I had my bed sprayed with linex they told me there was only a skeleton under the plastic and did not recommend spraying the tailgate
Edited by Greyhound6.2
Mine was sprayed with a bed liner from the factory. (Bed and multipro tailgate)
You should check your tailgate again, it's a plastic cover, not bedlined. It matches the look, but it is a plastic cover. I have the factory bedliner and multi flex tailgate I ordered from the factory.
You can probably use the DIY roll on or spray on bed liner. The heat the pros use would more than likely damage the plastic
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,253 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
