Anyone experienced the delay in Reverse on the 8spd trans? Happens after sitting for an hr or so like its losing pressure has has to build back up. You can get in, start it, then put in reverse and the engine will just rev for 3-5 secs before moving. Its been in and out of 2 dealerships for over 2yrs now with the same issue. Finally called GM customer care and got the ball moving on trying to get this resolved. Dealerships say they cant replicate it or they had to reprogram the TCM/ECM which does absolutely nothing.
We got clunker, shakers and delayed engagers!  Step right up...come on down!  We gots dem dare finest trucks in town!
If you're unfamiliar with HP Tuners this will look a little complex to you. Here is the base pressure for reverse compared to 1st gear. As you can see it calls for ~ 8 times the pressure of 1st gear, which has the highest psi of any forward gear.
With that said, I haven't experienced this issue with my 8 speed. Sorry that no one can figure it out either! Sometimes mine is pretty laggy and then it clunks but never that long of a delay. I'm going to experiment by greatly reducing the first two columns to see what happens and report back. If it engages quicker and with less force, then I'd consider it a win.
Lucas, you have one table in PSI and the other in KPA. So what you say is not as true.
If you switch to PSI for both tables they are nearly the same.
Edited by CamGTP
Crud! Good catch man. Considering I've never touched the reverse table that makes sense. I've played with 1-8 quite a bit and never liked KPA so I switched all of those tables over.
In any event I cut the values in half for the first two columns as a test and it feels no different. So therefore I dont think there's anything from a tuning perspective that can be done to help. But i have had the dealer flash "the latest calibration" before and then downloaded it into HPtuners and compared to before and haven't spotted any differences. So maybe their updates change something I dont have access to??
I am. Spent hrs and hrs tuning LS cars back in the mid-late 2000s. Unfortunately my car was broken into and my laptop/cables stolen. I reached out to HPtuners about replacements but they wanted me to buy all my licenses again as well as new cables etc so I opted out. Anyways, its at the dealership right now. They called this morning and stating they have an open case with GM technical assistance on how to proceed that it defiantly wasn't normal. Will update once I find out more.
Delayed engagement 8L90 has 3 seconds before GM deems out of spec?  Lol...sounds like a relearn probably to fix yours
3 sec is being on the low side. Its had about 4 relearns already. Just last week it had Fast Adapt Learn with SPS performed clutch learn with GDS according to the receipt I got. Did not fix it. Made it home from the dealership, parked in the driveway then left 45min later to pickup my daughter and delay was there. Doesnt seem to only happen after sitting overnight.
Ok, sounds like it's time for new valve body?
    • Length/amount of data capture will be important to consider, sifting through 5 minutes of a data log can be enormous when it is stored in milliseconds. Being able to find the 'event' let alone decipher it.   Presumably the driver would notice something and hit a button to capture the 'window' of data. That window has to be large enough for the operator to recognize the event and react accordingly.    The data has to be able to be retrieved easily.   The data has to be able to be understood. Which is the biggest challenge, dealer techs won't even know what most of it is and would likely not even look at it if an owner brought it to them. Meaning the owner, the least educated/qualified, trying to understand it.    How will the data be presented? Could specific PIDs be selected and a timelapse graph be watched? How will a specific value be noted as abnormal? Additionally, a good data logger would be able to 'learn' normal values for a specific vehicle and flag abnormalities automatically. It could in theory watch parameters degrade over time and suggest maintenance as needed. (If the MAF reading begins tapering off for a given set of other readings - MAP, throttle position, Ambient, etc.. a flag to check air filter.) With the amount of data available, a device (really the vehicle rather than an additional accessory) should be able to do more than issue a DTC. It should be able to run the full diagnostic suite automatically and present a solution rather than a code. (It's not the 90's anymore). The technology is available for the vehicle to not just say "P0087", it should know low fuel pressure, check other PIDs to narrow down the problem itself, and determine if it is a lift pump, high pressure pump, regulator, leak in the fuel line, clogged filter, etc. Even if it can't narrow it down, it should be able to guide the user to the likely problems.   This would be a major problem for dealer service departments, which are the manufacturers customers it is in their collective best interest to NOT have this available to the consumer.   Further, if the owner is going to be the primary consumer of the data, it's got to be at a consumer price point vs. dealer only specialty tool price.   This group is more 'involved' in their vehicle than general public/consumer and will have knowledge, experience, needs and desires that are quite different from the market at large.
    • I put the prof up. If you read what I posted. You can see that housing, cars and income are in line with the era we were talking about. It’s harder in some places easier in others. Let’s agree to disagree and put this back on track, OK? We both are pretty stubborn and hard headed. But I bring receipts. If you wish I will not respond to you in the future.
    • Lets see if I can sum up two pages of nothing useful.    You want to refute your own governments data of the "Purchasing Power" Index FOR THE ENTIRE USA and its territories replacing it with the experience of a single family and its business and label that reality?  Then pound on that for a week hoping it will find traction?    Stan, I've told you several times. I don't do irrational. There are more people in the USA than your family.    I'm pretty sure this tread is so blown up. I'll give you a few days or months if need be to post yourself silent then I'll see if I can find enough parts of the train to reassemble it.
    • Facebook groups hate VSE, poor customer service; their responses to criticisms are pretty poor for a reputable company. I'm not a customer, haven't bought anything from them, but how they handle themselves on social media is a definite "No" for me.
    • $10,000 for a transmission?   Pretty sure I could buy all the parts, tools, and education to rebuild it myself for a quarter of that amount.   or swap it out with a new one...
