Sister companies. Zone = entry level. BDS = competitive level.
Some differences in my research:
- Biggest= the “no fine print warranty” on BDS parts that is not offered by Zone.
“BDS stands behind its products and that’s evident by their No Fine Print Warranty. This no-BS warranty protects the original purchaser against breakage, bending, sagging, or any other usage failure. This “no fine print” lifetime replacement warranty extends to cover all BDS hard parts as well as bushings. Exclusions would be product finish and wearable items such as shock/stabilizer cylinders, tie rod ends and ball joints that would fall under the separate Limited Lifetime Warranty policy. Beginning February 1, 2020 all new kit purchases include the No Fine Print Warranty on bushings”
https://bds-suspension.com/policies
- according to my local BDS dealer, BDS comes with thicker gauge steel on supports/brackets.
- UCA should you choose to get appear more refined from BDS (tubular) vs zone (box/angles).
- BDS includes extra parts like the skid plate and rear shocks, at least in the packages I’ve seen, where as the zone does not. Once you add those, the cost becomes comparative. This does give you the option of “entry level” with zone as not everyone wants/needs a skid plate or upgraded shocks - if they’re not at risk of smashing the diff etc.
What I’ve gathered so far. Probably missing some things.
Thanks for all that-very helpful!
I’m going to go with the BDS.  Now the question is, do I have the dealership or a local shop install it?  The local shop is a certified BDS shop and they are a bit cheaper than the dealership.
If it is a GOOD shop and they've lifted T1's before, you should be o.k.  The CV boots on these trucks are hard plastic and are prone to tearing if the tech isn't careful during the installation process.  I entrust the GM dealer with this since they know these trucks best.  I have a good relationship with my dealer and their prices are in-line with the aftermarket shops around here anyway so it's a no-brainer choice for me.
After the install you will need it aligned - so if local shop can do that as well and they do lots of BDS lift install - should be fine - if not since dealer does BDS and can do laser alignment after - they may be easier.
You will love it - I love my BDS lift!
On 3/9/2021 at 9:33 PM, Shazbotthegreat said:
Got quotes for both these lifts (6 inch).  Kit/install for the Zone is $2300 and BDS is $2900.  Is the BDS worth the added $600?
I am going to do the BDS, what shop gave you this quote?  What state are you in?   Are you not adding the UCAs?
A shop in Phoenix, Az (BDM Customs, they have a good rep and are an official BDS dealer.) I have a zone adventure series lift on the truck right now that came with new UCAs and was told that I could use those Zone UCAs with either lift.
    250.3k
    BDS my HD
    BDS my HD
  • Who's Online   2 Members, 0 Anonymous, 600 Guests (See full list)
    • Hello hello looking forward to expanding my knowledge of the 2026 2500 HD that I just bought.   Truck has 3500 miles on it four-wheel-drive crew cab and I’m about to put a 6 1/2 inch BDS lift on it 18 x 10 -25 offset with 37’s   Already have the wheels and tires just waiting on the lift install in about three weeks   Question what surprises am I not gonna be happy with?  I’m not new to lifted trucks so I know that acceleration towing gas mileage all that is affected..   Question is those of you that have this truck this powertrain with a 10 speed Allison and have done the mods that I’m doing,,, how bad is it? Is that Allison constantly gonna be hunting for the right gear to go into? And what about towing, acceleration, fuel consumption as mentioned?    Lastly how come I can’t find any ring pinion gear set up for these axles and when could I expect to see them?   I apologize if there’s any typos I’m doing speech to text on my iPhone.
    • I've got a 2013 2500 6.0L Flexfuel. Drove the truck earlier today with no issues. Went to run an errand tonight and noticed key fob wouldn't work. Figured battery was dead, so replaced fob batter. Still wasn't working. Grabbed my other set of keys with the other fob and that one wasn't working either. So I manually unlock truck and insert key. Interior lights come on, dashboard lights up, turn key and truck starts. Turn truck off, like a moron, and try starting again. This time no crank, no click, no nothing. Lights still come on and dash lights up, but now I'm getting a service 4wheel drive, service tire monitor, etc. Check voltage on battery and Im showing 12.2v. Throw my battery charger on it and give it 15 mins and try starting again. But still no crank no start. Decide maybe its a bad battery, run to autozone grab a new one and put it in. Same issue. Disconnect battery and let it sit for 15 mins. Try again and still nothing. I had managed to roll the windows down earlier as its a humid night, but now I can't get them to roll up. Power locks are also not working now. Then randomly I try the key again, and it fires right up. Immediately I roll up the windows as we have nothing but rain forecast this week. I shut it back off wait 30 seconds and start up again. Worked a 2nd time. So turn it off, start putting things back together. Try one more time, and back to no crank no start. And now the car alarm starts going off. Had to disconnect battery and leave it that way for the night as I don't think my neighbors would appreciate my alarm going off again tonight. Any thoughts or help would be appreciated.
    • No one will care for you like you care for you. Do what you can for as long as you can. IMHO of course.
    • How about them NICKS!!!
    • Hi there.  Long time lurker, first post.    i have read the previous posts regarding the water ingress problem with this emblem.  I bought my 1500 SLT the  summer of 2025 new and after reading the MANY problems with these emblems failing I decided to install one anyways.  As per a YouTube video, I sealed ( or tried to) this sign with silicone sealant around the outer perimeter joint and the holes that were already somewhat sealed on the rear plate of the emblem.  And installed the connector assembly using dielectric grease on the connectors. The installation looked great and worked well for about 4 months……then FAILURE.  Grrrrrr…… I live in the great white north and wash my truck weekly in an automatic car wash  to keep the salt off.  Let me tell you that removing the old, failed emblem is a whole different animal than removing the OEM individual letters without removing the grill assembly. Mainly because the illuminated logo is built differently than the original letters which  you can remove the red surface lettering with a knife or some kind of blade which gives access to the tabs which hold the logo onto the grill. So I had to essentially destroyed the old emblem to remove it. Doing so killed my chance of doing somekind of autopsy on the failed , old logo.  But there was plenty of water inside when I ripped it apart.  Prior to installing the new assembly I tried it with the old harness and it works fine.   Does anyone have any insight as to where the water is getting into this emblem? I intend to seal the new logo with slow curing epoxy this time around using a syringe.  I think this newer emblem may be an updated unit which I hope GM got the vendor to fix. It has an October 2025 date on it.    If this one  fails,  I am just going to revert back to the non-illuminated letters….AFTER PULLING THE GRILL.    Any thoughts on sealing with epoxy would be appreciated. Thx!   Doug
