Just wondering what your payload capacity on your sticker inside door of 2021 2500 AT4s w/ diesel says.
My 2020 AT4 2500 had a payload of 3,048 lbs.
It was built with all of the common options and pretty much loaded.
I’ve since traded it for a 2021 3500 AT4 that is scheduled to be built next week.
My 2020 has payload of 3146.
I checked a 3500 AT4 online and its payload was 3740.
I wanted a 3500 long bed AT4....but could only find 2500 standard bed AT4 up here in AK. Max tongue weight on the 3500 was 3165 and my sticker has it at 2775.
My 2021 2500 AT4 Diesel, Crew Cab, Shortbed, with all options has a sticker of 3,084 payload.
Crew cab 4wd std bed 2500 L5P will have a base payload of 3563 on 18's or 20's, 3391 on 17's.
Options, including trim level, will reduce the payload.
fwiw,
In GM lingo short bed is only available on a 1500.
HDs have either std or longbed
All drw are longbed
1500 crew has short or std
1500 doubles all have std
1500 reg cab all have long
(Ya I know, back in the day, short meant 6.5')
    • Looks nice. I still have my 2000, 1500. Bought a 2025, 1500 for retirement. Feels solid. These trucks have a bad rap on the internet. My brother has a `24 1500, 5.3 with 52,000 miles. No problems at all. Mine hasn`t either but mine`s only at 12,700 miles. Have seen some of these things with 100,000 miles with no problems.
    • Howdy! New to the forum of course! My name is Casey, just picked up a 2024 high country midnight edition. First “new” truck in 24 years for me. Driving a 1998 Z71 since 2002. Have been on the GMT400 forum with lots of good info and help there. Nervous about driving these newer trucks and all their electronics…. Did a lot of work on the Z71 myself over the years. New truck is definitely a nice upgrade after 24 years. Photo of the old and new, still keeping the Z71 - has 320,000 miles on her and still running well!
