Hey guys,
I got a 2016 LTZ Silverado and I am looking at running either 33 or 35 Goodyear ko2s on the 20 inch ltz rims. I was wondering what the general consensus on if running 35s is worth it and how it effects fuel economy, towing, and acceleration.
Currently the truck is leveled, but if I got 35s I would lift it with a rough country 3.5 lift kit, and might even lift it if I go with 33s.
Tire sizes:
33s: LT275 /60 R20 119S D1 BSW
35s: 35 x 12.50 R20 121R E2
Thanks,
Buzzy
Edited by Buzz1
I went with a 2" front level and 33s, initially.
I then installed a 3" front level (removing the 2") and a 1" rear block with 1.5" rear spring lift - still had the 33 KO2s.
I put on a 1.5" body lift and thought "What about 35 KO2s?"
I'm glad I did it.
As far as the questions about towing, I haven't had 'em on long enough to provide feedback on that.
As far as fuel economy - not much different than the 33s - also, if one cares about such things, don't go this route.
Acceleration? On my 5.3, maybe a little different but nothing noticeable.
I'm glad I did it.
Do you have any pictures of it each way? You using stock ltz rims?
With the 33s
1 minute ago, MikeBMW said:
With the 33s
What size are those rims? 18s?
With the 35s (had to do two replies due to file size)
Yes, 18s so your 20s will be similar.
1 hour ago, WSFD6107 said:
35x12.5x20. Just soo you get an idea of the looks
Looks great, what lift are you running. Also does anyone know if you really need the .25 spacers with factory Ltz rims with their 3.5 lift?
Thanks, lift is a 4" ProComp. Not sure about the spacers with the factory rims. I have -35 offset with these rims with no rubbing.
I did a 2.5 level kit with new UCAs and 285/75/17s (34in) toyo MTs. So far Ive lost a like 3 or 4 MPG average watching the 25 mile avg tracker on the dash. I think stock ! was seeing like 17 or 18 more often and now im seeing anywhere between 13 to 15 mpg.  I remember I lost at least 1 mpg on highway driving just from leveling it and removing the front air dam under the bumper.
Im also not driving the highway as much with covid so thats a factor. Cruising on flat highway i used to see 18-20 instantaneous mpg but now its more like 15-17. I have corrected the tire size in the ecm btw.  You will definitely see a difference and bigger tires are not what you want if you really care about MPG.
On 3/18/2021 at 3:41 PM, Buzz1 said:
Hey guys,
Tire sizes:
Thanks,
Buzzy
I have the RC 3.5 knuckle kit on my 2018. I'm running stock gmc 20s with 295/60r20 falken wildpeak at3, they measure 34x11.5.
I am running 1.5" spacers and definitely had to do the norcal mod on the inner fender for clearance. Now I can fit my hand around the whole tire anywhere.
I didn't try my wheel without the spacers though. I like the stance from the 1.5" though
    • If one can't be found, a good automotive upholstery shop should be able to replace/sew in a new panel where the damage is on the old cover. It might not be the cheapest option..
    • Does your dealer charge you for the tire rotation on top of the oil change price ?. I haven't had any service work done at my dealer yet other than when I brought it back soon after owning it to have the front end aligned to correct the steering wheel being off center a bit. Oh they called me at least twice hounding me to bring it in for an oil change and pushing a 300.00 package of oil change and tire rotation and whatever other quick simplistic checks they would do. Only going off of what a friend gets charged for his half ton for the basic oil change and its the same amount of oil as the L8T holds, it was about 150.00. Once one buys a set of tires from most shops these days or so I believe, they will do free tire rotations and some do free tire balancing as well as free tire repairs.    Certainly doing a tire rotation is no five minute job, and definitely not at home but because I run a set of winter tires on their own wheels, I swap them at home and its a one tire at a time deal because of the tire season swap although I jack up the rear and do it and drop it back down and then raise the front and do them and coordinate the tire rotation into that process for both sets of tires. I am using a floor jack though and if I need to raise both ends at once I use a couple sets of jack stands to have all four tires off the ground. I use either an air impact or battery impact and have electric impact as well so no shortage there of easy methods to spin the lug nuts, and then retorquing the lug nuts. None of it goes quick though but my wages are cheap though ... zero. I live an hour out of town, its easier just to do things like that myself than waste a bunch of time in town and having to make an appointment and probably a special trip and sit there at the tire shop waiting for them to get my vehicle in and get it done and not screw something up in the process.
    • I do have the 8 speed.  Interestingly enough, after driving my truck for the past 2 days now, I have not had the clunking issue at all!  I am beginning to think it may have been suspension/leaf spring related, and somehow when the shop put my truck on the lift to do their initial inspection, it relieved some built up tension/pressure that was causing my problem.  I swear it felt I was a bull rider on a bucking bull the way the truck would almost rock back and forth slightly before the big thud/clunk when coming to a stop.  I am hoping I got lucky here and it's gone for good.
    • Bring it to discount tire. They do free rotations even if you didn’t buy your tires there. I didn’t believe it until I tried and they did. You can tip the employee if you would like
    • Best part of this video is how it resets expectations. Wonderfully done piece. It also made clear a few points I've made from day one. Detergent oils DO NOT KEEP A MOTOR CLEAN at the recommended or longer change intervals. They just get dirty slower than a non-detergent oil and there isn't spits difference between them on this point if they carry the DEXOS license. Great thing about the license that gets missed is it assures CONFORMITY even it that means a low bar.    One thing he did not talk about that I paused on an magnified was the condition of the oil ring separator. Besides a stuck ring a plugged separator and land drain back is huge when it comes control. We see in short order improvement in control IF that is the problem.    Another item I took exception to and he did not make plain was the condition of the timing chest and under valve cover having something to do with indicating piston cleanliness. Schaeffer's Oil makes that same omission in their million mile Ford video. I'm guessing he has never torn down a Red Line HP, AMSOIL SS motor that has been on that diet from the get. What he showed in the video was a good deal of varnish. Something totally absent in Peppers 165K cover off look. I smiled because he did his at the same milage.    He also makes the mistake of assuming oil temperatures in the pan are the temperature all over the motor even though he makes note of the piston being the hottest part of the engine. that baffled me a bit.    I can tell you from personal experience and witnessing teardowns of family motors that even oils of the 1960's would keep them squeaky clean when OCI's were 1500 to 2000 miles without exception. At 3K and above you get what he experienced and the longer you leave it the quicker to gets to the junkyard.    I think his is missing a opportunity not tearing it down again when he's done killing it. Time would be his only cost.
