Have an 03 Silverado that I'm doing some upgrades on to get her ready for camping season. Right now Im going to replace the brakes and would like the minimum thickness of both front and rear rotors to determine if I need to buy them as well when I place my parts order. Thank for the help, Mike
Personally if it were me, and this was a truck used to haul a camper, and you are truly upgrading it to get it ready, I would evaluate how long they have been on the truck, and make my choice from there. They are relatively cheap and easy to replace so it would be a no brainer.
Anymore it is just best to put new rotors on when you put new brakes.  Not to many places around here turn them anymore.  Besides, brakes are one thing I don't skimp on. Especially as often as you would be changing them.  Put quality parts on for brakes and feel confident that you have a vehicle that can stop like it supposed to with no issues down the road.
I would recommend doing both new rotors and pads at the same time. I have been pleased with my wagner pads, they stop great while towing and have worn very evenly. For rotors if you are doing them yourself I would recommend OEM going through rockauto or amazon etc. If you are having a shop do the work I recommend you go the local ford dealer. Why you ask? because in 2017 Ford started offering aftermarket parts for most make/models. The brand is omnicraft, that is what I put on my truck because I worked for a ford dealer at the time of replacement. If you have them done at the GM dealer they will give you a 12 month warranty. If you let Ford do the work they will give you a 3 year unlimited mile warranty on the rotors, labor included! I have had no warping issues, or any complaints more than 2 years later. YMMV but that is my 2 cents good luck with your setup!
well I will do the work myself just for the simply fact that the local ford places here in my area are all owned by 1 company and their a bunch of asshats.
    • True. My statement needs qualification. "For a shade tree mechanic, re-assembling the front engine to achieve a rough baseline timing of 0 degrees, as is approximated and indicated by common visual indicator mark alignment, measured with a human eye capable of 20/20 vision *with correction, I am reasonably confident that I have followed the outlined procedures/ prescribed methods for verifying baseline timing."   😉   In the end, the computer sets the timing, it's continuously variable based on sensor input, and the distributor only has a degree or two of physical adjustability intended for dialing in the final setting for cam ****** once everything is back together. But even that final value is acceptable within, I believe, +/- 3 degrees.   I thought my exhaust project was going to be a bear. To my surprise, the old clamps came right off last night, and I was able to unbolt all the hangers instead of having to muscle the rubber mounts. The old cat is ready to slip off the factory y-pipe. The rest is ready to come out with one or two cuts, and I've got a fresh blade waiting. I love living where rust isn't a thing.
    • I work at a Chevrolet dealership & hear it all believe me.  Just reads like there's going to be a fist fight over filters.  Can't get enough, continue!!
    • I just can't think of the exact term GM uses for that higher gvw package without looking at the website but basically sort of a trailering package and I imagine it may also have been created to skirt around the licensing fee differences between a3/4 and 1 ton that apply in some states although ironically I believe in some states its the reverse that a 1 ton is the cheaper truck to license over a 3/4 ton. It makes no difference here in Alberta but oddly enough a 1 ton through my insurance company is a bit cheaper to insure over a 3/4 ton as its based on the insurance statistics they generate.    For sure when ever you do have the chance to weigh your truck and to be fair, try to have the fuel tank full or nearly so rather than give yourself a false sense of the truck being lighter by having an almost empty tank.    In my other comment I was mentioning stock sized tires and partly in case someone was reading this and thinking they could lower their pressure down to what your aftermarket tires are able to do with your empty truck as that is a vastly different picture in the leeway you have to play with for running minimum pressures while remaining safe. I will say also that its easy to see from reactions of truck owners that may have been more used to owning a half ton in the past or a car and be it on a forum like this or in person etc that they get so wrapped up in that placard pressure sticker that they can't get their head wrapped around the fact that an HD truck due to how much it can carry can also vary the tire pressures drastically lower than those pressures ( typically more so for the rear axle on stock sized tires ) when empty vs some car that isn't made to carry much so the tire pressures can't be lowered since it needs almost that much pressure just to carry the empty car.    If I ever do find myself in the states with this truck, I will only be too happy to switch it over to the US measuring system as then I will understand all the dash readings. The only thing that is off for me slightly with US measurements is US miles per gallon as I grew up with the Imperial gallon and to this day up here anyway speak in Imperial miles per gallon ( I don't do that on this forum though as that would confuse everyone for no good reason ).
