13 hours ago, Dogdad said:
My truck is finally going in next week for leaf spring replacements. There is also a bulletin out on this matter..
Thx for posting.  The above "cause" doesn't seem right.  Definitely don't hear it going over normal road bumps......it's when the truck isn't level.  Like noted above, when turning at slow speed and road/truck is pitched at small angle.  Seems like it would be bushings on, like noted above, loose u-bolts.  As noted, mine has gotten worse with more miles (at 3800 miles now, all on-road and essentially clean roads).
On 4/6/2021 at 6:08 PM, Dogdad said:
Found out today that the thumping noise is indeed the leaf springs. Took a whopping 10 seconds of riding with a service manager   for him to know what it was. They wrote up a ticket, ordered the springs,  and will call me when they come in. The guy was great and professional. He said they are seeing issues with the new trucks and the whole leaf spring has to be replaced.
Do they have any answer as to what’s wrong with them? Just bought mine 3 weeks ago and noticed the same noise. When I get under it and have someone rock it the noise sounds like it’s coming from either the front bushings or the rebound clamps. I have the max trailering package. I’m wondering if this is an issue with all their springs.
Did you see the post above with GM bulletin notice in regards to this. The shop foreman at my dealership will be working on mine himself and said just replacing the bushings does not fix the issue. So he ordered the whole package to replace mine. Tuesday is the lucky day to get fixed.
I did see that bulletin. I noticed it on mine with like 300 miles while backing in my driveway. I haven’t been out in any bad weather so it’s not debris and wouldn’t think the ubolts are loose. I was going to torque them for the heck of it but didn’t get a chance. There’s definitely play somewhere in the springs that’s causing it. Let us know how you make out with yours.
I don't hear it when the truck's level, going over a speed bump at slow speeds, for example.  But as you noted, when turning at slow speeds into driveway, which often throws the truck slightly out of level if the driveway starts an incline from the road, is when I hear it.  I would think if it were the Ubolts, I would hear it over all bumps, not just when turning.
I think mine just started making this same noise in that last 1500 miles; I notice it the most backing into a parking spot. Like most things that have popped up on this truck it is still intermittent, so I wonder how the dealer response will be.
Did they put your new leafs on?
20 hours ago, Dogdad said:
They did today. No more thumping noise. Took about 2 hours.
That’s good news! Hope it stays that way
Well, it didn’t last long. Thumping noise is back as before after new leaf springs installed. This is a problem that GMC needs to get resolved.
Edited by Dogdad
At least they are attempting to fix it. The dealers here in Georgia won’t even try to at this point. Still very frustrating and not something you should be experiencing with a new truck.
Edited by GeorgiaRST
That’s sucks, sorry to hear. I’m thinking to try the rubber between the leaf suggestion or maybe even put some spring clamps on that front section. Total bs though to have to do anything with a 60k plus truck with 500 miles on it.
Edited by intimidator01238
Ok…bought the “Spring Thing” rubber spacer kit. I don’t have  a jack or jack stands so I had my dealership install them . They work fantastic. No more noise at all. The shop foreman actually did it for me. He said their dealership actually had been putting rubber bushings they made a couple of years ago and it solved everyone’s clumping noise. However, GMC came down on them and said to quit doing it and they stopped paying the dealership for the install. GMC is putting these cheap plastic spacers in that don’t work. He said it’s only a bandaid fix. So, I recommend these rubber SPRING THING. Easy install . There’s a video on their website showing it. Here’s mine installed.7BEDD327-B128-4E8F-A8C7-378788138F67.thumb.jpeg.ffde22d679daae42627336625e28d3b7.jpeg
01B7052E-9ADC-4C47-8405-AC6EF91E6CC8.webp E4D40E3F-1B40-4338-870F-BCFF257645BA.webp 995B9B4D-295C-410A-A78B-D2582D49DF90.webp
Check out my last post. Installed the Spring thing kit. No more clunking sounds finally!!
Edited by Dogdad
    • The BORA 3/8" spacers arrived yesterday along with the extended lug nuts. I got the front wheels changed out today, but was overheated and covered in sweat so bad, I figured getting both front wheels done was a win, and took a cool shower. Hopefully, I'll go out tomorrow morning before it gets into the 80+ temps and do the backs. After getting the first wheel snugged up, I backed out one of the lug nuts then hand turned to count threads. I believe I stopped counting around 12-13, so I think I'm good there.
    • My fullsize truck is averaging over 26mpg so I'm pretty happy with the increased fuel economy targets. When I had my gas Silverado (2020 5.3) it was averaging 21. Again, for a fullsize truck, that's very different from the 12-15 these things used to get 30 years ago.   Whine all you want, increased MPG is a good thing.
    • That is a fair point, and I think an OBD-first proof is probably the right next step. I agree that the value is not the hardware box by itself. The marketable part would be the software: always-on capture, baseline learning, event reduction, system-specific reports, and alerts. Also agreed that if an OBD device is always plugged in and has local storage, it should not miss the event in the same way that a scanner plugged in after the fact would. The only thing I would not want to assume yet is that an ELM327-class device gives all the late-GM data needed at the rate needed. Standard OBD live data, DTCs, freeze frame, Mode 6, VIN, and calibration information are definitely the right starting point. GDS2 also proves that a lot of useful ECM data can be viewed through the DLC without needing a DTC first. The question I need to test is whether the data needed for a useful GM V8 event report is actually available through the DLC, and at a useful sample rate: - misfire counts / roughness by cylinder - AFM/DFM state - oil pressure and oil temperature - fuel trims - voltage / reset context - U-codes and communication events - calibration / software information - whether these are standard PIDs, enhanced DIDs, Mode 6 data, GDS2-only data, or not available So I think the right benchmark is: 1. Build the OBD-only version first. 2. Keep it plugged in and logging locally. 3. Compare it against GDS2 / freeze frame / HP Tuners or another higher-end logger. 4. Measure which parameters are available and at what update rate. 5. Only justify ECM-side hardware if it captures useful evidence the OBD version cannot. So you may be right: the consumer product might simply be an always-plugged-in OBD event recorder with much better reporting. A question for you: when you say ELM327 devices can already deliver all the data needed, do you mean generic OBD Mode 01 data only, or GM enhanced data as well? For a useful GM V8 report, would generic OBD data be enough, or would you expect the tool to include enhanced items like misfire by cylinder, AFM/DFM state, oil pressure/oil temp, U-codes, and calibration information?
    • 87 down as low as $5.14 here... winning!
