We got some rain last night and turned my wipers on, everything was working fine until I got off the exit and the rain stopped, so I turned my wipers off and they remained on. The variable speeds work as they should, so that leads me to believe the switch is good. Double checked the fuse even though it should be fine and it was good. Disconnected my battery to reset the computer and they are still stuck on.
Having issues finding anything online pertaining to my year, older models have some kind of pulse relay but from my understanding these years do not.
Any suggestions or insight would be greatly appreciated!
Look and see if you have a relay for your wipers. It has Likely fused together. Pull & replace.
Sent from my SM-N975U using Tapatalk
From what I've read online, these years have solid state fuses on the BCM. Going to pull the switch tomorrow and check to make sure it's functioning correctly first.
Thanks for your response!
Solid state relay. Not fuses. There are called PCB relay's. Printed circuit board. Not serviceable, would need a new underhood fuse block if that is what diag indicates.
