Hey all,
anybody know what mods I can do to help with the efficiency of my power? (For eg, lighter pulleys etc) I don’t know what’s hot and what’s not here. I’ve basic engine mods and don’t want to spend $$$ on getting more personality out of the truck. I’ve heard gears are a good start. I’m rwd btw
Nobody has ever changed pulleys and gained anything.
Rear end gears depends on what you have now and what you are willing to give up. If you went down to 3.08's that would make it slower but also lower the rpm on the freeway, which could improve mileage. Or you could go up in gears to 3.73's or 3.90's to improve performance and also maybe help with mileage depending on where you live. Maybe it won't down shift as much and cause more fuel usage.
Get light weight wheels and tires. Anything heavier than stock is hurting mileage, big lifted trucks will notice that more. Drive slower overall, if the speed limit is 70mph, do 65 instead.
  • Thanks 1
I think I may not have explained myself well enough. I’d like to plant the power to the tires more efficiently. I’m not too concerned about gass
Gears and traction bars if you have wheel hop issues and need more traction.
4.10's or 4.56's with a tune will run like hell in a light weight truck. A lowered RWD truck is going to need traction bars from somebody like cal-tracs. You'll get wheel hop/axle wrap like crazy if you don't have something like that.
Edited by CamGTP
I don’t have many mods. I doubt I’ll hop lol as cool as that would be!😁. I’ll only have intake/l86 tb& mani, muffler delete and a tune
Gears = worthless for anybody that has normal sized tires, has 4wd, and 8 or 10 speed.
for the amount of money and labor it cost to change the gears in the front and rear diffs for negligible results, you’d be way better off just putting that money into making more power.
This equation becomes even more true with more transmission speeds.
There are two torque multipliers, your transmission and your axle ratio. All that matters is how many times the motor spins to how many times the tires spin. When you have 10 f-ing speeds in your trans, it can create nearly whatever freaking ratio it wants to at any time. Changing just the rear end ratio does jack ****** unless you have monster tires and you just want to take some mechanical stress off the drivetrain components between the diff and the transmission.
I have a six speed, rwd. I have 24’s on 305/35’s. Not sure how big the diameter is. Is it still a waste of money? I don’t have sc or turbo money atm. Or is there anything else that you’d suggest that would give more life or personality to it? I do city/hi way driving and don’t tow. I’d like as much acceleration as possible keeping in mind that I don’t want to be doing 5500 rpm at 130kms/hr. Is there a specific gear for this? Or another type of mod that would help plant my existing power better?
With a 6 speed and heavy ass 24's, you for sure want gears.
Even if you don't make absurd power, I can bet you will get wheel hop. I can make my truck wheel hop pretty easy with a 5.3 and 3.42 gearing. If you have 3.42's now I would suggest 4.10's. It'll only increase the cruising rpm a few hundred. Instead of 1,600-1,700 at 65-70mph it'll be closer to 1,900-2,000. I didn't use the online calculator for that, it's just what I sorta remember.
Edited by CamGTP
Those are some heavy tires. If you are geared currently 3.23 running in 5th gear will spin like 4.10 gears on the highway. If you have 3.42's then 5th is like a 4.30. And if you have a 3.08 then like a 3.90 gear. Your tires are taller than stock so not exact but within like 50 rpm. If you can live with that a gear change will be good. Thing is I would not expect the G80 to last long. The are several lockers that can be used.
Traction bar, yes. Now that done a driveshaft upgrade. Then a looser converter with a trans cooler. Of course this sort of kills it for towing. Circle D or PATC are good choices.
    • Compression test? Weird noises? Fuel trims?
    • I suspect at some point in the near future, the hardware will be free and you pay a subscription to access the vehicle - alldata style.
    • I've been eyeing an upgrade to my tonneau cover for a bit now.  Intrigued by the BAK MX4 EZ-Lift with the torsion spring and went for the upgrade.  Thoughts and musings during unpacking, install and a few days of usage.   Once my order went into Realtruck, it took about 4 days to ship.  Unfortunately, FedEx Ground destroyed the box and contents and it was unusable upon receipt.  To Realtruck's credit, one email with pictures and an RMA was sent to me to send the first one back, and another unit was shipped out.  It arrived 3 days later, unscathed.   I opened the box and it looked like every other BAK MX4.   Biggest differences are the rails and retaining clamps, and of course the spring attached to the cover itself.     NOTE - if you are upgrading from a MX4 to the EZ-Lift, you will have to replace the rails.  The EZ-Lift rails have a notch cut in them to allow the new style retaining clamps to fit properly.  The new retaining clamps also have 2 knobs/carriage bolts and there are two tracks underneath the front panel. The strap clips are mildly different (more like the Undercover Flex clamps) in that the screws go in from the underside.  Personally I prefer these over the BAK clamps that use the nutserts that are a nuisance to install.  The remainder of the parts in the box (drain tubes, rail clamps, and bumper pads) are standard issue BAK.     I did not replace my front bed seal at the time because it seemed to be in decent shape.   BAK recommends shims on the GM trucks unless you place the clamps on the flanges about 1/3 of the way in from both the front and rear of the bed.  I shimmed the front and the middle, and initially placed the clamps equidistant.  This also turned out to be a mistake, because when I set the cover in place, the new style retaining clamps wouldn't clear the front clamp.   New style clamp inserted in the track:     And the issue which occurred because the front rail clamp was too far forward:     Once I removed the shim from the front of the bed, and slid the clamp back to the front flange, everything cleared fine.     The cover set on the rails without issue and I installed the strap clamps.  After I completed my adjustments, I pulled the pin to activate the torsion spring.  Mistake #3 on my part.  PULL THE PIN AS THE VERY VERY VERY LAST STEP!  The reason is, once you pull the pin, the torsion spring is activated.  If you have to loosen the front clamps and adjust the cover, the front panel will - by virtue of the spring, refuse to lay down.  The only way to get it to lay down so you can reinstall and tighten the clamps is to fully open the panel against the back of the cab, which will then allow the front panel of the cover to lay down and be tightened.  Not a big deal unless you haven't installed the foam pads yet (typically the last step) because minus the foam pads, you will need to place something between the frame of the cover and the back window so it doesn't get scratched.  The next time I install one I will install the foam pads before I pull the pin and activate the spring.   After using it for a few days:   The spring assist is great.  You literally can open it with one hand.  My shoulders aren't getting any younger and this was part of my motivation to swap out. The second panel latches and unlatches itself as you open and close the cover.  Neat in concept, however it took me a minute to get used to closing the cover and not hearing the "latching" sound that would tell me it was locked in place. The paddle handles are a huge upgrade and I wouldn't be surprised to see them become the standard across the Realtruck line.  They effectively eliminate the concern that a thief could coat hanger the cover open and get to the contents in the bed. I'm not sure why the very front panel on my cover has a different finish from the other 3 panels.  I have a request into Realtruck to find out if mine was not manufactured properly or if it was by design.   All in all I'm pleased.  Same level of protection, looks good, keeps stuff mostly dry (they all leak around the tailgate) and easy to install.
