I replaced every bit of my brake system from master cylinder to abs sensors. I had the abs module rebuilt. Test drove and the pedal is still spongy. Clues?
Did you bleed everything completely, including the ABS unit? Bench bleed the master cylinder?
yeah even old 1995 cars had atleast 70 feet of brake lines feeding the abs system, you need whats called a pressure bleeder with a 2 liter tank to flush the abs and lines.
I did bleed but as another  poster said, I'm going to use a pressure bleeder. Thanks
I think that's the answer. Thanks
