Anybody out there ever get this message on their display? "Service Emission System" all to find out it was a reductant system tamper code? Just wondering if this could have been from just recently using cheap O'Reillys DEF fluid because they were out of blue DEF. Some folks tell me it doesn't matter but sure is a coincidence that I got this message 3 days after pouring the cheap stuff in!
doubt it. most people use the cheapest stuff they can find.
I personally us the regular Blue DEF.
however, there have been numerous reports of issues after the Blue DEF "platinum" stuff is used. GM blames it on Peak, Peak blames it on GM.
The blue def normal works good. So does the shell rotella DEF. The blue def platinum gave me poor def quality errors then service emissions system. Running it low and shell rotella got rid of the errors. Never had any def or emissions errors with anything except the blue def platinum. Take that how you will.
On my recent road trip pulling a 17,000 gvw toy hauler the service emissions system light came on around 175 miles from my house. We stopped at a local GMC dealer and was told the dpf needed to be replaced and they could not get one for 5-6 weeks. They reset the computer and gave us enough miles to get home and cancel a trip we had planned for 6 momths needles to say we were very disappointed
I know none of them are perfect, but good lord does it seem like GM can't get their crap together with the emissions.
Across forums for all 3 brands it seems I see more complaints about L5P emissions than the other 2, which sucks because I'd really love to trust a Duramax
    • I have A 2020 1500 5.3 8 speed. LTZ. Transmission problems since 60,000 miles. Started when I go to store in morning to get my morning coffee before work leave truck running get back in put it in drive/ rev no movement step on gas a little slams into gear. Put in neutral step on gas little shake then put in gear and gose.  Shut truck off start .. ok now at stop light stop truck after a few seconds feel a little kick if that doesn’t happen stuck in 3/4 gear shut truck off wait few seconds and start usually ok again. If you down shift manually ok as long as you get into 1st before stop. If not it kicks . I WANT A NEW TRANSMISSION. Now I want a new truck it just hit 80,000 IDK IF ILL BUY CHEVY CAUSE THEY STILL HAVE THE PROBLEM AND REFUSE TO RECALL . Oh I’ve changed the fluid and filter 3 times now. And yes used mobile 1 not ac/delco cause it’s not meeting the requirements that mobile is did use ac/delco filter
    • Of course refrain from political debate but I myself have very dismal hope for what is all going on up here every where we turn so I nodded my head when I saw this joke.
    • I'm looking at carpal tunnel surgery on my left hand and lumbar fusion.
