When you think about light bulbs we know they aren't covered under warranty.  However, several of the lights on the upper level trims don't have bulbs to replace because they are LED.  For example, I have a 2020 Trail Boss LT.  From the factory the headlights, tail lights, and fog lights are all LED.  Some models, such as LTZ, High Country, and those with the Midnight Edition package also have LED turn signals.
Now, here's the purpose of my thread.  My left fog light is out.  I went to pull the bulb so I could get a number and be able to replace it, however I found out there's no bulb.  The light sticker plugs into the whole light assembly.  When I looked up the cost for a replacement fog light on GMPartsDirect I found no bulb listed, and the whole light assembly is over $100.  Thinking I would find the part cheaper at Rock Auto, I searched there, too.  That's when I became aware there's a core charge for the fog light of $50.  With the core charge, on Rock Auto the cost for the fog light is $166.
Now, if this was a simple bulb I could see event laughing and telling my to spend $2 to get a knew bulb, but that's clearly not an option.  And, half the time I use my fog lights the left light will come on.  However, a few minutes down the road and it'll start randomly flashing.  The other half the time it doesn't light up.
Do you think the dealer will warranty the lamp, or are they going to try selling me?
The LED fixtures are covered under 3/36.  If you look at your GMC or Chevrolet warranty tracker you will see incandescent bulbs covered for 12/12.
Wow, that's pretty ridiculous, imo. I hope the LEDs last a long time based on transient's post, because 100+ to replace a 2 dollar bulb.
There's no bulb, unless you consider the whole fog light assembly a bulb.  Imagine the outrage for a LED headlight that's $600-$1,000.
Sorry you're correct. I mean it in the context that you can buy replacement pcb's with diodes for 5 bucks. But it's going to be a real bad day when people are starting to have to replace this stuff in the future. It's almost like they want these new vehicles to be disposable.
Baja Designs has a very nice replacement for the factory fogs that adds double the light output.
Isn't that meant for trucks that don't already have factory fog lights?
  • 10 months later...
I suppose you might be wrong. Of course, such simple lighting as LED strips is hardly covered by the warranty because it is too small and very easy to replace (if you know how). However, it's quite possible to guarantee such a product as a bright LED spotlight for a dome or fog lights. When I bought my spotlights on vont.com, I got a three-month warranty. It was a good purchase. The light beam coming out of the spotlight was very high-quality, distant, bright. I like how it works. Why don't you ask the store employees if they have any light bulbs or spotlights subject to warranty?
Edited by JesseHiserp
  • 1 year later...
Yes! The new style General Motors vehicle front and rear headlights with the LED bulbs you cannot get to are fully covered by the 3 year 36,000 bumper to bumper warranty. I just had my rear hatchback taillight assembly replaced on our 2021 Chevy Traverse. They had it 2.5 days though due to the number of people out there now getting their vehicles repaired over buying new. So please know that this is fully covered by the warranty because there is no way to get to those bulbs and replace the individual bulbs. It’s truly sad to think of the future for a lot of people with these vehicles after warranty is up because these assembly’s to replace are between $300-$500. Isn’t it fun as time passes by in this world? Companies get smarter at taking our money. :-(
    smandy
    smandy
  • Who's Online   2 Members, 0 Anonymous, 527 Guests (See full list)
    • Holy s**t - not much of a parts thrower you say? You BLASTED that thing with the parts cannon!  You'd have been probably $1,000 ahead if you had just brought it to a competent shop rather than shotgunning a bunch of parts it clearly didn't need.   Just FYI - oil additives are really, REALLY good at ONE thing ... and that's emptying your wallet. They're ALL useless gimmicks.   If that has the L94 or L99, then #7 is an AFM cylinder. I'd suspect a failed lifter in that case.   If you leaned on wiring, sensors, and/or connectors while changing the oil, you'll have to check all that to be sure pins didn't get pulled out, connectors broken, etc.. Old wire loom that was barely adequate when new is certainly brittle by year 19 - make sure wires aren't chaffed and shorting out somewhere where you might have leaned. or supported yourself on it.   If your a mechanic, why didn't you just find out what you were missing and troubleshoot from there??  TIMED spark, fuel PSI / injector pulse, air, compression.  Can't make ANY money going the parts cannon route.
    • LOL! Are you joking?? That wax SUCKS! 100% gimmick made to "look" good.    After just TWO winters I had severe surface rusting in patches over 90% of the frame. Only reason it looks great in the pics is because I SATURATED the frame every single fall with used motor oil for 14 of the 16 years I owned it. Otherwise it would've been sent to the crusher 8 years earlier with the speed it was rusting prior!    I sold that POS 3 years ago. Was a gigantic headache the second it rolled off the showroom floor. Brakes pulsated on the TEST DRIVE. Door trim fell off the 1st week! Interior squeaked and rattled, and the drivetrain clunked after 2k miles. 4x4 switch failed shortly after. Front end - ball joints, struts, hub bearings - all failed between 38k-50k. Engine started burning oil at 50k. Rear and and transmission failed before 100k. Nothing but problems, and frustration with the piss-poor engineering designed to make you give up. Well, it worked! Nothing on that truck was easy to remove ... except the wheels. They haven't figured out how to screw that up yet. Give 'em time ...   I won't make that mistake again. EVER.   Such fond memories ... https://postimg.cc/K1qf23tS  https://postimg.cc/gallery/X02z64J  https://postimg.cc/gallery/mHSRXZv  https://postimg.cc/gallery/D4mMRfL
    • Different monitors do their test only under conditions specific to that monitor.  you MIGHT find the drive cycle conditions for the monitor that isn't ready on this site: https://lemon-manuals.la/   If it's not there, then it should be on alldata.com for your truck, but it requires a paid subscription.   And you need to know which specific monitor isn't ready.
    • from another thread   Update...although the truck sometimes seems to idle weird and the transmission shift a little weird, I've driven about 7,000  miles and no issues.   However, the way GM has handled my rental reimbursement, the situation when my truck quit, and the recall in general has led me to this point...I have driven a GM vehicle for the past 46 years and unless I buy a C3 Corvette, this is the last GM vehicle I will ever own.
