9 hours ago, dennismc said:
My 3 month old 21 Sierra SLT has developed this problem on the drivers side but its intermittent, usually when I first start it its white like the other side then will change to a lite blue and pretty noticeable. Of course took it the dealer and it stayed white! Lol
Has anyone else had theirs act this way? Will it eventually stay blue?
Exact same thing happened to me today, took it in and the Blue Light Special turned white
When I first start my truck, it’s perfectly white like it should be. After running a couple minutes, It turns very noticeably blue. However, it’s very consistent, I’ve never had it stay white for longer than a few minutes.
  • 1 month later...
On 6/22/2021 at 11:26 AM, 2021 Sierra X31 said:
Ha! Well mine appears more purple... and it’s only the drivers side. So, my OCD won’t allow that 🤣
Hey new to this forum, was wondering what they did to fix your issue? I have a 21’ Silverado LTZ with the same problem. Had my drivers side headlamp assembly replaced and within a week it was purple again. This is extremely frustrating!
well, mine still isn’t fixed. They have to replace the entire headlight assembly, as it is built in one piece. I took mine to the dealer a couple of weeks ago, they swapped the light for the new one. I drove it for four days and it had already turned purple again. Now I’m just kind of waiting it out to hear that they have actually issued a bulletin or have confirmed to have headlight units that are no longer affected with the issue. Obviously the one day swapped me for Was an older production unit that still has the problem. Or, possibly there is an issue on the truck side that is not related to the light that is causing it. I have not talked to anybody that really knows what is causing the failure. You could always have them order a new light and give it a shot. No guarantees.
Well looks like we are pretty much in the same boat. Idk how many people actually pay attention or care but I have seen many new trucks with the same issue. I did have mine replaced and the new one turned purple too. So like you I’m wondering if it’s a issue with the truck causing this and not the light. Hopefully a tsb will come out on it. Those headlamps are really expensive so I can’t see them continuing to replace them without a more permanent fix. Well good luck with yours, if you do find out any info please lmk.
  • 8 months later...
I’m having the exact same problem now whereas my left (driver side) DRL has turned a purple color. It drives me crazy that they don’t match anymore. I have an appointment at the dealer for it in 3 days. I’ll post about what the outcome was.
Just took mine in a second time. They are replacing the headlamp again. There is another thread on here about this, one or 2 of the guys said that replacing the entire assembly fixed theirs... so it now seems they had a huge batch of these lights that had an issue in manufacturing, and that now they are finally producing units that don’t have the problem. I asked the dealership if this issue was document yet via a TSB. They said no. GM knows they have a large problem and they are just trying to damage control at this point I’m sure. One of these headlights is over $1000 each. They ordered me a new one that was actually sitting in North Carolina. Who knows if this is one that has had the issue corrected or not. They aren’t releasing any dates on when or if they have fixed the problem. I’ll keep taking it in until they fix it.
    • Folks, Have a great new 2026 WT  (std cab, 2.7/4WD) w/base 40/20/40 mech adj bench "fake buckets"  (with lower and upper center console) heavy vinyl seats.  Overall the seats are very comfortable and the vinyl is heavy and appears less likely to 'split out'. Am very tall (6'5")  + a bad back/osteporosis/former hyperparathyroidism so ease/range of movement is a bit restricted.  The truck rides a bit high and I use a nerf step bar w/my left foot to step in, then I put right foot/leg in, drag my butt in  & get seated.  Worked fine in my 2018 RAM quadCab. But I end up dragging my butt over the left raised sidecushsion area of vinyl seat, and due to texture there's fair amount of traction on slide inward.  (ArmorAll didn't improve.) If the seat were even ~1/2" - 3/4" lower it'd be helpful, but base seats just have the forward/backward underseat bail and the side lever for tilt which really doesn't affect seat height.   I really don't want to 'de-puff' the left side sidecushion forming the  fake 'bucket'. I know one company sells 'seat elevator blocks':  but is there a simple way of lowering the height of the driver seat instead?   Thanks Bill W San Jose
    • I have a basic 2026 1500 WT  (2.7L/4WD reg cab shorttbed). Comfy, generally happy with electronics/radio - but is there a way I can add switches to steering wheel right-side position (curr. empty) so I can adjust volume, push phone button to voice dial, etc? Bill W San Jose
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
