So just bought a 2014 Sierra with 80k miles. It just started smoking from the tailpipe.
Here’s what happened: dealer did the oil change, and a couple weeks later I started hearing a tick. I checked the oil and it was 2qt low. I put about 1,000 miles on it like that. Additionally, the coolant was a couple inches below the full when cold mark when it was cold.
dealer said the tick is just the direct injection noise, nothing to be worried about. They gave it back to me to keep an eye on it. Now it’s starting to blow while smoke on start up in the morning. I have my thoughts but wanted to get an opinion on the smoke that’s coming out. Thanks!
Edited by Grandst2014
Add photo
Seems normal, mine does that every morning when I start via Alexa, the myChevrolet app or the remote.
It's a cold start thing.
When it's warmed up, do you see the same?
White smoke is, generally, water burn-off.
Edited by MikeBMW
I wish the video would upload. Doubtful it’s water burn off from normal condensation. A literal cloud went by my window which prompted me to get out and have a peak. Haven’t seen it do that before. The only time any vehicle of mine did this is when it had a bad head gasket. I’m thinking it’s more likely an internal coolant leak. The reason I’m asking is to get opinions on the possibility of it having something to do with the dealer under filling the oil by 2 qts. That and the fact the coolant was very low has me concerned.
My 06 Silverado started doing the same thing at 230k, and by 250k it was like a billowing cloud every time I started it cold. Not a normal cold start issue.
I did a side by side comparison with another vehicle. The vehicle I had parked next to the 2014 all night, didn’t even make the slightest wisp of smoke under the same temp/cold start when I took the pic of the GMC.
Does it go away after a minute or so? Mine has done this about a half dozen times. Do it once then nothing for a year then twice in a week and again nothing. I now have 135K on her. Uses no measurable oil. Uses no water. No explanation I can think of. it does it in all four seasons. But never from more than say 30 seconds. Sometimes it's even blue. I think it is a GDI thing doing a bit of cylinder wash.
If it's a white cloud on start, and goes away after warmed up, no issues.
If you are experiencing a constant white billowing on startup, even after warmed up, look for a coolant issue into the engine - that would not be good.
Else, you are worrying a bit more than you should.
Example this evening:
P.S. I, also, learned this evening that I need to hold my iPhone 12 Pro Max camera in the upper left hand orientation when taking a landscape vid else it's upside down when uploaded - hence the need for two starts.
Edited by MikeBMW
  • Haha 1
Man, I was waiting for that Panther from your last video to pounce on you🤔😬
Since I am sort of pro at taking these post off the road into the ditch, what is the cool looking dial above your light switch?
  • Haha 1
That is a Curtis Spectrum trailer brake controller I had installed by the dealer since mine didn't come with the factory trailer brake controller.
Edited by MikeBMW
1 minute ago, MikeBMW said:
That is a Curtis Spectrum trailer brake I had installed by the dealer since mine didn't come with the factory trailer brake control.
Good looking clean install. How does it work?
There is a push button to allow different modes and the dial sets the trailer brake sensitivity.
The service guy chose the spot - similar to the trailer brake location of this series - the new model have it on the other side.
I bought it from Chevy accesories and, really, I gotta quit searching that site! :D
I typed "Curtis" but I meant "Curt." oops!
https://www.curtmfg.com/part/51170
Yea, any one named Curtis is going to be bad news😮🤔😬🤟
  • Haha 1
Thanks for the replies. Seeing as I mentioned the coolant was a couple inches below the full mark and needed to be filled, and I just bought it, I’m going to pursue the cause. If it was a truck I had for a couple years (and wasn’t under warranty) might think differently.
@Grumpy Bear blue smoke is not normal. That said, no oil use, I might not worry, unless I just bought the thing. lol.
I hope you learned to check your oil more.
@diyer2 Does anybody actually pay attention to read on this thing? I had the oil changed at the dealer and it was 2 quarts low from them. thanks anyway. Keep your snark to yourself, not too helpful.
    Sothpaw27
    Sothpaw27
  • Who's Online   1 Member, 0 Anonymous, 451 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
