I have a 2021
6.2
at4
that I bought new in January
experienced severe engine knocking yesterday
took it in to dealer I bought it from and they think it maybe a stuck lifter
but they don’t know for sure
very very frustrating
could be 7-10 days without my truck
anyone seen this ?
Yes.  You aren't the only one.  4000 mile Tahoe sitting outside my view here at work getting all 16 lifters and 4 pushrods right now.  Lost a cylinder on each bank.
GM has dealers replacing all of the lifters on whatever bank(s) there are failed cylinder(s).  You will get it back and it will be good as new.
Edited by newdude
Having the same problem with the 5.3. Only 2300 mile on it. I was told that GM knows they have a problem. As a result there are no parts available because so many truck across the country are breaking down. I was told that they have know idea how long the truck will be down.
Question
is this issue being caused by the afm?
if so if I get my truck back I’m thinking of Getting the pulse to disable afm
issue :
We are currently in the process of dismantling the affected side of the engine. We have had parts ordered for it. I should know more tomorrow.
Lifter, push rod head bolts and gaskets
Problem is they just get replaced with the same failing lifters, this has now been an issue with the 6.2 since 2014. Gm clearly has taken the we will just fix the broken ones instead of doing what's right and making a part that won't fail.
5.3 as well, same lifters.  Its not always the lifter's fault either.  A mis-time of the VLOM/DFM solenoid can send or pull oil at the wrong time as well.  The bulletin for 2014-2018 trucks they want all AFM lifters on the failed bank(s) replaced as well as the VLOM which now conveniently ships with AFM lifters in the box.
Edited by newdude
This best part is there are no trucks to replace my At4
it’s a standard bed which apparently over the last 7 years is frowned upon in a half ton
my truck is very specifically setup for what I do everyday
Since this latest generation I’ve had new standard bed z71 or x31
2015
130,000 miles
transmission replaced at 108,000 just out of warranty
2018
Z71
60,000 miles
no issues
2020
x31
32,000 miles no issues
and now this gem 2021 6.2
all others were 5.3
I bought my 2021 Chevrolet Silverado LT around April 2021.
Several days ago the engine started knocking when in operation start up and running operations. Oil levels good and not due for an oil change.
I paid a lot of money for this truck wondering if this problem been reported to GMC.
Its definitely problem they need to know about this issue.
I was so shocked when the Tow truck driver told me that he had to tow 6 of them in one day with the same problem as mind.
Edited by Larry Richardson
So, how about miles, engine, CEL's, loss of power, rough idle while "knocking", drop in fuel economy before it started?
Is your truck still under warranty, did you report it, or file a claim? Have you heard back from dealer? Do you really believe the tow truck driver, or was he just shooting the S**T with you?
Lots of pieces in each puzzle, much easier to solve when they are all there.
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
