I am embarrassed to say after being optimistic on here about spacer leveling kits, I now have a minor potential issue....
When turning the wheels and driving slow, I often hear pops on front end. I believe i have closed in on the issue and believe its to do with the sway bar.
Everything is tight, and the level is new, I don't believe there is any damage yet.
I am asking for help on tightening and troubleshooting the sway bar and popping noise from it.
Any advice? this is driving me crazy
wanted to clarify, the truck is a 1500 GMC Denali with ARC, level kit is 2.5" Rough country spacer
  • 2 years later...
Hey, did you have any luck figuring this out? Just put a level on my truck this weekend and had a clunking. Everything is tight, got it aligned and the shop said they tightened up the sway bar end links and the rattling seemed to go away but now it’s back again. Don’t really want to have to take it off now but seems like it’s a common issue from some of the forums I found.
Check the top strut bolts. They’ll seem tight when the suspension is hanging but then at ride height they will have slop and be loose. Impact them down.
live and learn....which i have with spacers
yes i have a 2025 ultimate denali 1500 just got it leveled with 2 inch rough country kit and i hit the smallest bump and get the clunk noise took it back to the shop they say everything is tight. I dont know what to do it still makes small clunk noise.
When you complete your final torque down of the nuts for the suspension, do it with the truck on the ground.  Torqueing to spec on an unloaded suspension is no bueno.
thank you, ill let my off road installers know this solution. you would think they knew this already. hmm
  • 10 months later...
Replying to this thread because it’s the first thing that pops up on Google. I had the same issue and it ended up being the sway bar links. GM updated the sway bar links in 2022 with longer ones.
if you have a 2019-2021 Silverado, you added a leveling kit and you’re hearing a clunk at slow speeds check your sway bar links. Have someone rock your truck side to side on the front and go underneath of it and give it a listen.
You will need part # GM85590925.
SEO: 2019 Silverado 2020 Silverado 2021 Silverado 2019 Sierra 2020 Sierra 2021 Sierra clunk after leveling kit
