So I know the actual towing numbers aren't much different, but what would be roughly the payload difference between a LT 2500 and 3500 gas? This would be a crew cab, not sure if the standard vs long bed really makes much of a difference.
Yeah I know you can find exact numbers on the trucks themselves, problem is there are no trucks near me!
I looked into this same thing and there is roughly 600 pounds different in the payload capacities. Just got lucky and found a 2500HD Chevy High Country and snapped it up. I would order a 3500HD though if I had my choice.
48 minutes ago, nick112288 said:
Does bed length come in to play on it?
Ram and Ford offer the larger fuel tanks with long beds so they make sense to me on those
Not necessarily as GVWR goes up to match cab and bed length.  Old body 2500HD were either 9500 GVWR gas or 9900 GVWR diesel.
What comes into play is engine choice and wheel/tire combo.  17 inch SRW trucks have lower payload and GVWR than 18 or 20 inch wheel SRW.  In the chart below you will notice this.
This is also why 1 tons only are 18 or 20 inch wheel trucks.
Here is the 2500HD GVWR listings.
To understand the model codes for each one:
Example.  CK20903
CK - 4x4
20 - 2500hd
9 - long bed
03 - regular cab
So that said:
CC - 2WD
CK - 4WD
20 - 2500hd
30 - 3500hd
7 - standard box
9 - long box
03 - regular cab
53 - double cab
43 - crew cab
Also on fuel tank size.  GM relocating the DEF tank under the truck screwed up the tank sizes.  2011-2019 they were all 36 gallon on gas and diesel.
2020+up, all gas are 36 gallon.  Diesel crew cab all beds are 36 gallon.  Diesel double cab are 36 gallon long box and 29 gallon standard box.  Diesel regular cab are 28 gallons.
GM should have left the DEF tank where it was like on 2011-2019.
  • Sad 1
2 hours ago, nards444 said:
Isnt there  a pretty big towing capacity difference between the two, its like 4-5k lbs.
Not the gas models. They're rated within 100 or 200 pounds of each other according to the 2021 towing guides
No your right between each model with each engine.
Common GCW so max gooseneck will actually be on 20 series truck because they weigh the least.  Buy a 30 series if you want to push the limits.
#iworkforGM
Just for a data point, my 2021 GMC 3500HD SLT CC LB SRW Gas with front camper spring option , 18 inch wheels, premium pkg, and second battery has a payload rating of 4054 lbs.
Soon, what your saying is...  I can haul more than 4000lbs in the bed of my 2021 Dually?  Right on, right on man.
Show me your sticker I highly doubt that I could be wrong but I highly doubt that I got a 2021 GMC sierra 3500hd regular cab 8ft bed srw 4x4 sle 6.6l gas with camper springs20210726_204534.thumb.jpg.4ae4b9e04b835609fd7ddbb23b8fca06.jpg and I'm pushing 4430 payload I highly doubt the crew cab is only 376lbs heavier the diesel in your configuration weighs 8200lbs+
A 2500hd CC SRW LT Gas weights in at 7161 I kbow your 3500hd is slightly heavier let's just say it weighs the same the gvw on a 3500hd gas is 11,100 lbs minus 7161 gives you a 3939 payload capacity that's based in the weight on a Chevy 2500hd CC SRW LT Gas yoyrs should be around 37-3800
Edited by Zani Koxha
    • It's possible the two trucks are using different body control modules which is why yours works and the OP's doesn't.   So much in these newer vehicles depends on model/trim configurations, production date. They don't all use the same modules like back in the day.
    • I forgot to answer the question as per what market mine is set to and yes I finally found that area on mine and yes its also set to America.   So here's something I realized as I wasn't looking at that part in the Sierra section until now, your right that what I see here as choice 3 under Sierra which says 07/2023-06/2026 ( 433 MHz 13542523 ) it has no choice 5 for tire pressure selection. Where as it does under the Chev choice. However I kept going down the list within the Sierra and I am really wondering if choice 9 will work for your truck as it has the same model number and hertz sensor as my truck. I would say try that choice first, if that doesn't work then jump over to the Chev section and again choose that same model and hertz choice as for some reason the Chev section gives the choice 5 of tire type/pressure selection for going back a number of years. Could very well be an Autel thing that they just didn't get the updates all done properly under Sierra but anyway first try that selection 9 I suggested under Sierra and then go from there.
    • Looking for this piece that holds the hose clamp in place. I have the hose clamp just not that other piece. Dealers and wrecking yards in my area will not sell just that piece. They want you to buy the whole air tube $100 +/- to get that $5 part.  that piece isn't molded to the air tube as I looked at my friends truck. It's held on by a screw and nut. I'm trying to put the OEM parts on the truck as the previous owner butchered things up installing an aftermarket CAI. It really looked homemade. 🤣 Thanks
    • Ok I missed that part that yours is a GM. The strange part is that the choice for year ranges and within the year of 2026 is different on the Sierra then on the Chev for some reason as I am looking at my tool at the Sierra choices. Now I am guessing you see as to your sensor part number as it may be different on your truck for some reason and a call to GM should get you the part model number of the sensors you should have as well as which MHz your sensors are. I know mine are the ones as per what I listed but there are other choices in the Autel and got me wondering if by some chance they put different ones in your truck. Having said that, did you try using each of the choices starting from No 1 and going on down the list, not sure if that would mean shutting off the engine each time and resetting the tool and going at it again each time. Also I thought of something else which may sound retarded but if there was some stupid chance that the chev choice would work. The reason I say that is that the Sierra is showing a range up to 06/2026 for the various choices of sensors it could be where as the Chev has one choice that has that 12/2026. By the way it is possible to not run the truck and you may know that as per not pressing the brake but pressing and holding the start button for a few seconds and it lights up the dash ( its called service mode ) but that sucks battery power and if it were me doing it that way I would be throwing on a decent sized battery charger before doing it that way as killing your battery won't make you happy at me at all !.    Like I say, just a thought to try the Chev choices if you have already exhausted the Sierra choices but first it would be nice to know for sure what exact sensor model and hertz your truck uses as I assume only those choices that mention the sensor would work unless a choice that does not mention the sensor model would somehow work. Its frustrating when one is trying to use tools like this without the experience of the tool and the vehicle, as I am sure dealer techs themselves struggle with it when starting out or a new model year comes along that is slightly different.
    • I tried before I updated the scan tool just incase an update messed it up, but it never worked so I updated the scan tool and it still didn't work.   Only difference is I click on Sierra not Chevrolet cause I have a Sierra.   If I click on 2026-2024 I didn't have any option to change placard, when I click on 2023 it does give me the option but when I try to do it,.it says vehicle not supported!   I have my region or market or whatever it is set to America I think, is that what yours is set to?
