I had a shop put a 2” RC leveling kit on my 2020 Sierra and ever since then the road noise is has been very bad. It’s like all I hear when driving it now. Just a whirling sound all the time that goes up and down in frequency. Never noticed it as much without the level. On gravel roads, the suspension is not deadening any of the sound from the road, just a constant whirling. However, on a perfectly smooth road, it’s as smooth as ice and I can’t hear anything hardly but once I get on a smooth but grittier road the same whirling sound comes back. I was wondering since there’s not as much weight on the front now if that’s why I’m getting so much road noise now. I haven’t gotten an alignment yet either but seriously think that wouldn’t help as much as I’d hope. Any ideas?
Did you have it aligned after installing the level?  Everything tight?  Any CV boots ripped?
No weight was taken off the front of the truck BTW.  Its not like you put 400lbs in the bed of the truck against the tailgate to "level" the front.  That is how you take weight off the front.
I installed mine myself and it made squealing noise when driving it after the install but it ended up being the brake dust cover got bent and just had to bend it back out.  Maybe thats all that is wrong with yours.   Take the wheel off and spin the rotor with your hands and see if it makes noise and then find where the flimsy dust cover is touching and bend it back away from the rotor.
It has not been aligned yet. For comparison, I drove the same truck except it had the 2 inch lift (not level) and it was night and day difference. The steering felt heavier along with the front of the truck. That’s why I was thinking the weight has shifted towards the rear. The whirling noise could have been there before the level and since it’s a new truck I’m just not used to the road noise it normally makes. Getting an alignment on Monday, along with tires balanced/rotated. Hoping it will correct the issue. I can live with it but I’m considering lifting rear now to force more weight back on steering.
Why wasn't your first response to take it back to the shop?
It’s not a squeal, like I said in OP, on a perfectly smooth road, the noise goes away, but as soon as the road gets grittier, the road noise becomes very noticeable, more so than I noticed before leveling the truck. I drove my fathers diesel 2020 half ton gmc and his has the 2 inch lift and it was very solid and not as noticeable road noise.
I called the shop and talked to them about it. They suggested getting an alignment which I’m getting on Monday.
The "road noise" as you call it likely is due to the tires. Your modification has changed the way the tires interface with the road surface. You didn't say if they are OEM or oversize. Oversize tires are just plain louder.
How many miles on the current tires? how often do you rotate them? are they worn unevenly at all?
Getting an alignment and making sure your air pressure is correct will make a big difference.
The steering feel has changed because of the alignment being off.  Raising the nose up 2 inches those tires are toed in pretty good right now.  Leveling changes all of the geometrical angles of the CV, control arms and most importantly the tie rod ends.
Your tires went from |  |  to  /  \  from the toe being too inwards now.
The tires are OEM with 14K miles on them. I just purchased the truck used so I’m unsure about the rotation schedule or if they’ve been balanced yet. Hoping an alignment cuts down the road (tire) noise a little more. Just seems way more noticeable than before the level, every little rough patch in road can be easily heard.
Thanks for the response. Yeah that makes sense. You think an alignment will help with the sound issue at least? I’m going to have the tire shop check everything while they’re down there and that nothing was damaged in the install of the leveling kit.
Yes an alignment will help.  Your tires are scrubbing going down the road essentially chewing rubber off of them.  This is going to make noise.  Get an alignment ASAP unless you like spending money on tires.
Also, the truck will still make more noise than you were used to because you've now changed the airflow under and around the truck.
I hear the same whirling sound going over gravel too and I didn’t hear it that well when I test drive a brand new one off the lot after the level. I know the brand new one had 15 miles on the tires whereas mine have 14K miles on them. Same tires but mine aren’t aligned either. Could that cause that much noise reverberating in the suspension? It feels like it’s absorbing too much sound from what the tires are riding on, gravel, semi rough roads. Perfectly paved and the sound is very minimal and what I consider “Normal”. Just wasn’t sure an alignment could play that much of an impact.
I’ve had bad tires before and it sounds like they’re not making an aligned contact on the road but when my 115K mile Ford is quieter than my brand new GMC, something is off.
Like I said earlier, I can just hear way too much road noise almost to a point I can’t see tires being aligned making that big of a difference….? I could be wrong and hopefully I am.
    • What meaningful corrections were done to fix the "machining errors?"   I bet nothing, because the 6.2 is soon to be obsolete. Why would GM implement any fix let alone an "expensive one?"   Until someone can provide any convincing information that GM did ANYTHING to correct the engines - the 6.2 is no for me.    Which means keeping the 2016 Denali longer until the next generation (6.6?) proves itself.
    • If my father took a Sunday off. We did the Sunday drive. Usually stopping at a Geno’s for dinner that we eat in the car. Six of us with my little sister up front. It was always a Buick growing up. In New Jersey you couldn’t get lost. Not like Texas.
    • Hoooooooly smokes, batman!
    • I suppose I am Atlas. It can always be worse, eh?   I had a friend once that rolled one payment into another until he was paying the price of Benz for a 10 year old back marker. Wouldn't be often you start a new payment the month following your old one.
    • I still enjoy the drive   Some people fish when they retire; some golf. I drive. We've lived in the same general area now for twenty eight years and I'm still finding at least monthly some sweet quite little road to explore. When I tell the Mrs. I'm heading out for coffee she knows that could be a five hour event. Often she even goes along.    I like finding new rural routes used mainly by the locals that start nowhere in particular and end the same way. Many in the area of that type are narrow paved and twisty, hilly and run through field and timber. Often along creeks or wetlands. Unfarmable areas of great natural beauty.    After years of this type of exploration they start to fit together. One ending a mile or so from another and you start threading together a new path from a unfamiliar place to a new adventure. Sometimes to a little town of under five hundred that used to be something before the Interstate or some railroad or US highway bled the life out of it that has a small dinner with the greatest slice of pie you've eaten since grandma made her last. A little village museum or library or even a town square park with grand old oak, walnut and Osage orange trees to sit under while you sip you gas station coffee and chat up some locals.    Often they are full of stories about the main streets more interesting buildings and the who's who of the area. Sometimes some hidden attraction or unseen history. Our area is full of old coal mines.     A younger self used to do this going cross country by motorcycle. Only a general area as a destination with no time to get there and no time to be back. Sitting at days end in a 10 unit off the main highway motel under a Sycamore tree yacking with the owner or his one semipermanent guest while I adjusted valves or the chain. Always a wave and a shout "Hey there stranger"!  It's how I came by my love of old Brit iron. There is no such things as a ten minute gas stop when your on a Enfield or a vintage Triumph. Same being true of old cars.    If you take the time to really look I've found everywhere is someplace interesting. Illinois or West Virginia. Different and yet the same.    People are in a more relaxed mood and will talk about anything and everything and if they like you there may be a cupp'a or a lemonade and a sandwich in it. 😉
