2015 Sierra Denali. New Trans at 40K Cam and Lifters at 50k. Brought it in last December. Told them Motor and Trans both experiencing same problem plus oil pressure at idle under 30psa. I lobbied for new motor and transmission.
The dealer found bad lifter in #8 intake. Wrote up as replace cam and all lifters. Transmission was serviced by putting special fluid per GM I was told. I asked what happens if I have a problem with either repair when picking up the truck.  I was told 3/36 warranty
Now at 102k less than 3k miles later. Engine started running making noise. Back to the dealer. I get the call. You need a motor you dropped an exhaust valve. An exhaust valve? Yes sir I'm told. You had an exhaust valve break in #8 cylinder.  Okay, its warranty right? No sir. Why? "Well sir it wasnt related to the repair made. This has nothing to do with the cam and lifters or intake valve."
After reviewing the original repair order I also noticed that although the repair order was written up replace Cam and all lifters, they only replaced 8 lifters which I'm guessing were the intake lifters and they did not replace the exhaust lifters. I have always been told you dont use old lifters on a new cam.
I am supposed to speak with service manager today.
They have offered to pay half. My end $3500. I think they should pay for the repair and the new repair is related to the previous work.
Any suggestions?
IMO
I think they should fix it for free.
But
Pay the $3500 and move on if you want to keep the truck.
Pay the $3500 or less to a lawyer and try to get the repair for free.
Any suggestions?
Welcome to the site.
You are kind of married to this dealer at this point, what kind of relationship do you have with the service department?
At 102,000, I would open a claim with GM, make sure you have your records handy, you are not that far out the powertrain by miles, but date of service might get you.
Does not hurt to try, if they pony up some more money, your debt is getting smaller.
Remember, if you do not ask the questions, you will never know the answers.
  • 4 weeks later...
    • Folks, Have a great new 2026 WT  (std cab, 2.7/4WD) w/base 40/20/40 mech adj bench "fake buckets"  (with lower and upper center console) heavy vinyl seats.  Overall the seats are very comfortable and the vinyl is heavy and appears less likely to 'split out'. Am very tall (6'5")  + a bad back/osteporosis/former hyperparathyroidism so ease/range of movement is a bit restricted.  The truck rides a bit high and I use a nerf step bar w/my left foot to step in, then I put right foot/leg in, drag my butt in  & get seated.  Worked fine in my 2018 RAM quadCab. But I end up dragging my butt over the left raised sidecushsion area of vinyl seat, and due to texture there's fair amount of traction on slide inward.  (ArmorAll didn't improve.) If the seat were even ~1/2" - 3/4" lower it'd be helpful, but base seats just have the forward/backward underseat bail and the side lever for tilt which really doesn't affect seat height.   I really don't want to 'de-puff' the left side sidecushion forming the  fake 'bucket'. I know one company sells 'seat elevator blocks':  but is there a simple way of lowering the height of the driver seat instead?   Thanks Bill W San Jose
    • I have a basic 2026 1500 WT  (2.7L/4WD reg cab shorttbed). Comfy, generally happy with electronics/radio - but is there a way I can add switches to steering wheel right-side position (curr. empty) so I can adjust volume, push phone button to voice dial, etc? Bill W San Jose
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
