So I read a lot of posts on tranny problems on the Silverado 6 speeds. I haven't had any problems as of yet 112k and counting, but was wondering should I change the torque converter because a lot of people say to do it. If the answer to this question is yes. What replacement should be used.
If it ain't broke, leave it.
Did you do fluid changes?
Yes I have had tranny serviced at the dealer. No issues at all with the truck. Had all maintenance done at dealer at recommended intervals.
Decreasing interval lengths may be helpful after 100K. IMHO idunno if it helps, but I have had my trans replaced, unexpectedly.
If your truck has the 4.3, just give it the required severe schedule services and it will last a long long time. Forget the rest of this post. If however this truck has the V8 continue on.
https://www.sonnax.com/tech_resources/845-6l80-6l90-transmission-tech-advisory-consider-an-updated-converter-in-your-next-rebuild
I post this each time this question is asked and it is asked allot. Read it in it's entirety and really think about the "how and why" these failures happen. It's almost like asking if it's a good idea to continue bending a coat hanger as it hasn't broken yet, right? Then asking if you should replace it with the same type hanger!
Yes, it is true that those who service it regularly and treat it kindly get longer service life from their units...most...of the time.
This is just information you can use to make a decision with. I'm not telling you what or how.
Replace it. My trans looked great at 103 when I dropped the pan to do the filter. TQ converter went and wiped that trans at 106k. 5000 dollar repair at a dealer.
So I have 62k on mine and it was slipping a little. Just had the pan dropped and filter replaced.
shifts firmed up a lot, feels like a new trans.
Wondering if you guys that had a fluid done and then it went, noticed something similar
Better shifts after fluid is normal for the 8-speed (can't speak on others). If the TC chuggle comes back, that's also normal after a few thousand miles, but varies on how soon. For me, got on it one day entering the highway, and didn't shift; slight hesitation then dropped to low gear/high rpms, all at 65 mph. Beginning of the end.
I have a remote filter on mine , just changed it after 3000mi and was getting brass glitter flakes, I'm at 50,000 miles, all stock and t-stat removed. I am concerned since i only drive it on weekends and never tow more than twice a year.  gonna pull the pan on it soon take a better look. I have disabled the Lockup in 1-4th gears, so should be very little wear on the tcc, i think i'm having bushing issues instead
there is a relearn function on these transmissions which corrects for leaky pistons and slipping,  but only the dealer can do the relearn proceedure..
Edited by pokismoki
i used to get the chuggle on the 6 speed when i was moding the slip parameters. when i set the v4 mode , in TCC lock I zeroed out the slip and it would chuggle and viberate a lot, , then i went back to the 10-20 rpm slip in lock up and the vibes went away.
So question, if your trans is starting to do the bucking/slipping and fluid is burnt, is the trans salvageable or is it toast at that point? My suburban just started and was gonna take it in. Shop has been in business since 1971 so they know they’re stuff but curious if there’s any hope of not replacing the whole thing.
Got my answer. Was told they’d just replace everything out of precaution as they don’t know what the trans May or may not have digested so far. It sounds like it could be salvageable but not worth the fuss when throwing in a reman. $4-5k repair…. Ouch!
the high temps  in the converter kills the o-ring seal that keeps the lock up clutch pressurized.  this will exhibit a lock unlock condition, probably never lock up after the o-ring has shrunk and cant hold pressure
Good to know
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
