40 minutes ago, NCCaptainMorgan said:
Got my new 2021 AT4 HD and love it.  Every time I turn it off it tells me to check the back seat.  I thought it was only supposed to tell me if I had something heavy enough in the back seat.
I could be wrong but I think it will say it if it sees that you opened the rear door and then resets on the next ignition cycle.
No its to check the back seat for kids is what that is,  has nothing to do with weight or doors.  Go into settings on the DIC or radio and you can turn it off.
  • Rear Seat Reminder
    • Helps to remind the driver to check the back seat(s) before leaving the vehicle
    • Activates when rear doors are opened and closed up to 10 minutes before or anytime while your vehicle is on
    • Under certain conditions, once the vehicle is switched off, designed to sound 5 audible chimes and display a visual message within the Driver Information Center
    • Activates only once each time the vehicle is turned on and off, and would require re-activation on a second trip
