This is the first truck I have ever owned. Even though I am not planning to tow in the near future, I would like to go ahead and have the things I may need so its not something I have to go get when the need arises. What all would I need to have to tow properly and safely? Wiring harnesses, balls etc. My truck is at stock height at this time. I tried looking through the manual but I cant say it was a great help to determine the best course of action. So with that said, I defer to the experts here. Any advise is greatly appreciated. Thank you.
That is a pretty open ended question.
First, what model, and then what options does your truck have? Does it have the factory brake controller?
What do you plan on towing, small trailer, large trailer/boat, and have you ever towed anything before?
Ball will be determined by tongue on trailer, along with wiring harness, which your truck should accept both 4 pin (non brake), and a 7 pin (with trailer brakes) if it came with the factory towing set up.
So, I have over the years bought different size balls and drawbars to have just in case the need arises. Hitch pins are cheap, Bolt Industries makes pad locks, and the hitch pins that match the key to your truck, so you need one key.
I would figure out what you will be doing, then give yourself enough time to get your supplies.
I have a 2016 LT. It doesn't have the controller to the left of the steering wheel if that is what your are asking.
There is nothing in particular I have planned on towing. Granted I do understand there are roughly 3 standard ball sizes that would go with the trailer you pull. This was more to get what I could in case the need arises. More like I have the money now and would like to get at least most of it.
As for wiring, there are two items near the license plate. I know one is for breaking the trailer from trying to read the manual but not sure what the second one is for.
I havent pulled anything in a long time. When I was a teen, we had a Glastron boat I have towed up to the lake and I have towed my own car on back of a U-Haul. Beside that nothing of a constant nature.
You should have something similar in your bumper that looks like this. It has two "doors", one for the four pin connecter, which would be your small (U-Haul) trailer without brakes, and the 7 pin which will work with trailers that have brakes on them.
As far as the other stuff, just buy a 1 7/8", 2", and a 2 5/16" balls, and drawbars for each, or a drawbar that has all 3 sizes on it.
Get a good heavy duty tool bag under you back seat, and put things in it as you go along.
I have hitch pins, drawbar and ball, locks, tow straps, gloves, and so on in mine in case I need to tow something for myself, or a friend.
See the source image
Edited by JimCost2014
Without the factory controller, for a trailer with brakes, you would need to add an aftermarket unit if you did decide to pull a larger trailer with a brake system set up on it.
Pretty easy addition.
So I do have that to the left of the license plate. There is something else to the right of it.
For the drawbar, how much of a drop should I look for or just a straight one? I did see some with all three balls and it did cross my mind to get it and be done.
So, since I do not have a controller in the cab, the 7pin does me no good because my truck will not break the trailer?
Already on the straps. I had to buy two for when my wife purchased some outdoor chairs from Wal-Mart lol. Need more though. I am thinking of getting tie downs for the bed also. Too bad I didnt have those when they put in the liner.
The object to the right is for access to you spare tire, need your key to take the lock out if it is still there.
Drop depends all on the the trailer tongue, I went with a 2" drop just to be safe with my truck at factory height. Works with most trailer I have pulled.
You can still pull a 7 pin trailer, you just will not be able to control the brakes on it, but the lights will still work.
I use these in my bed, like them a lot.
31 minutes ago, Byrds8 said:
Yea, I like that one.
Check out MikeBMW's profile, he has a blue one installed at his local dealership.
He some good pictures so you can see how it looks.
Maybe even PM him for more info if he does not chime in.
I really appreciate all the advise and help. I have owned six Camaros in my day and finally decided I needed a truck. Looking back, wish I would have found a good deal on one with a Duramax engine but its all good. I love my truck for sure. Just purchased some new wheels for her too. Should be in in a week.
You are very welcome.
Post some pictures of the mods and the new wheels.
New wheels will not be here til next week. Havent modded the truck too much yet other than debadging, black bow ties, catch can, tint, modular intake tube and drop in filter.
Think to most, that is a few things😂🤣
  • Haha 1
Forgot catback lol. Well my last ride was a 2013 Camaro SS. It had the badging changed out to the old script, coil overs and lowered, extremely light weight wheels, full exhaust to include LTs, CAI, Tuned, two 10" subs, sub amp, heritage grill, catch can, tint. Thats what I can think of atm lol.
Here is a picture of the front of the truck though. I will post images of the new wheels after she gets them on. They only weight 28 lbs also :D. Dropping about 6lbs per of unsprung weight. Gotta call that a win. Forgot, that antenna is no longer there either. I got a much shorter one.
Edited by Byrds8
    • And so you had gone through the process of registering and updating the tool and so on ?. All I can say is that on the front page as the tool fires up you go to advanced mode, then vehicle model comes up and you choose Silverado ( not the DRW or EV  since your a single rear wheel ) , then I think its choice 2 which is 07/2021 - 12/2026 ( 433mhz 13542523 ) as that is the series of tpms sensors and then go down to choice 5 which is tire type/pressure selection. Hit yes and it says to connect to OBD port and turn ignition on.    Having said this, I updated the software in my tool lately and these year range choices look different from the past due to them doing some updates it would appear and I have not connected up to the OBD port since last year so hopefully I am not in for a surprise with them screwing up the software and that it won't work on my truck anymore either.    So my question is, when you plugged into the OBD and started your truck it had that message on the Autel screen "vehicle not supported" ?. That does seem odd as tire shops would be pissed right off if hey can't use their tool on the model year after mine that in theory is supposed to be much the same truck ... unless GM did some change in the computer system to block certain things from access.
    • Understanding and using modern scan tools is its own body of knowledge. I had little hope that would work...programming access to the BCM is probably required and that is not easy for us consumers. Expensive scan tool, GM programming subscription, online authentication, etc.   It also may be a matter of finding the right dealer to program it for you. Flashing a modern BCM might be a little too advanced for most tire shops.
    • Update for anyone following:    Installed everything as shown in diagram. Opted for 8 AWG from Battery Positive to a 50A resettable inline breaker. 8 AWG is tied into to 2x 12 AWG wires feeding a 6 way fuse bus in parallel (manufacturer’s design of what I purchased).    4 of the 6 fuses available for circuits are tied to terminal 30 of each relay. I tied a jumper from one of my spare circuits off the bus to terminal 86 of each relay. The trigger, terminal 85, was pulled from my interior by way of T-Taps from the X61A-X5 pins 10, 11, 17 and 23. This was the hardest part of the job. Even with the X61A unbolted and the X5 removed - there was VERY little wiggle room.  I added back up lights that I want to come on with my cargo lamp - but when I would check continuity between S48A-X1 pin 18 to its respective landing point on the X61A-X5 it triggers the factory relay… Instead I opted for a add-a-fuse on the passenger interior fuse panel (fuse location 10 - cargo lamp) and ran it through the boot on the driver side to my load. Did this to avoid introducing any electrical gremlins.   Note: Please check for continuity between the S48A-X1 and the X61A-X5. In my case wire colours were not the same as other’s who have posted. To do a continuity check you need a Multimeter. Completely disassemble the S48A-X1 and remove the brown face plate off the X61A-X5 by way of a flat head screwdriver - this was the only way I could get any results.   The outputs, terminal 87 of the relays, were fed into a junction box and landed at Individual studs and were labelled Aux 1-4.    At this point, all you need to do is run wire to your loads and bring them to ground. I created a negative bus in the engine bay, all my negatives land here.    For anyone having issues with all of your new aux switch lights coming on with the press of one - I noticed this only to be an issue when the battery wasn’t hooked up to my relays? No idea why, but it was quickly corrected by having my system buttoned up and functional.
    • Well I ordered the Autel ts508, and it won't work on my truck I tried all the 2023 and everything it just says vehicle not supported lol   I'm able to send this unit back, so I'm going to do that, then I'll just stop into a some tire shops and if none of them are able to do it, I guess ill have to spend a bunch of money to get a good scanner..... Thanks GM lol
    • Don't need the air tube but that's how everyone sells them. Most places won't remove that one piece and sell it alone. No money to be made. Hoping someone swapped theirs out for a CAI and no longer wants it. Not asking anyone to give it away. Offering to buy it but I don't need the tube. It's held on by a hex head screw and nut. Been all over eBay.
