Which magnetic drain plug? All I have seen have glued in magnet. Any recommendations?
garyo
What is your opinion about the magnet being glued on? I have seen some reviews where the magnet fell off in transit, not very confidence inspiring. Especially when both the block and pan are aluminum, if the magnet comes off it's going to stick to a moving part, not good. I know the Dorman is glued on, but don't know about the Dimple-sent em an email.
Thanks for the replies.
garyo
garyo
The magnet is Neodymium the the Dorman is steel. Pretty sure it won't fall out. Glue is a formality.
But lets say you can't live with that. Buy a few small N-50 Neo magnets off Ebay and stick them on your filter. Move them to the new filter when you change it out.
Edited by Grumpy Bear
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
