5’8” Short Bed
6.2L Gas
Ebony Twilight Metallic
Ordered May 31, 2021
Traded a 2019 Ram 3500 DRW
Delivered June 16, 2021
Picked up June 18, 2021
Mods:
Removed dealerships logo chrome badge from tailgate
Embark LS Power Retractable Tonneau Cover 19419848 GMC
LED GMC black emblem pack 84741561 GMC
Borla Cat back exhaust 19419433  GMC
Front console organizer 84106530  GMC
Rear underwear storage 84734683 GMC
Ceramic Window Tint: All doors, rear window and brow.  Rear Doors and back sliding glass and brow= 5%.  Front doors 25%.
Vedder Holster installed in left side of front console for Sig Sauer Emporer Scorpion .45  VedderHolsters.com
Installed the Red “Horse Ranch” decal ETSY
GMC fuel cap ETSY
2 Silicone Key Fob Covers ETSY
2 Red Silicone License Plate  ETSY
2 pairs of cup holder coaster ETSY
Ordered from:  Boost Auto Parts:  Pigtail to make all lights function at once
Ordered from Local accessory shop:  Go Rhino RB20 Running Boards sprayed with bed liner,  B&W Tow and Stow Hitch
Future:
LED Reverse and License Plate bulbs
Bed Mat to go over bed liner= save knees
K&N air filter OR
CAI:  by Cold Air Inductions
Aeroskin (Lightshield?) Bug  Deflector
Pedal Commander
Sierra badge on tailgate to black/red
Stubby antenna
Console Liners from Amazon
GMC puddle lights
Nice rig!.....you will love it....I just got mine a month ago in cayanne red tintcoat.
The LED bulbs for the license plate are made by "Lasfit" L-T10 model .....they dont throw codes, I replaced mine.
Check out the Rotofab cold air intake ,they make 2 different models,one for the 6.2 and one for the 5.3 litre and doesn't throw codes,that one you are looking at I believe adapts to the bottom part of the stock cold air intake box and wont give you the full potential of a cold air intake.
That GMC performance exhaust wakes right up after about 900 miles to....mine sounds great now after getting broken in.
I like the mods you have done and plan on doing, gonna steal a few ideas👍.
Question, What size tire are they putting on those stock 20" wheels?
Thank you.
Edited by Liquid Plumber AT4
WHAT IN THE HOLY HELL IS THIS, LOL???!!!
  • Haha 1
It’s called storage for a work vehicle- you don’t like it?  Well it’s a matter of taste.  Later mods include lift, shells , tires, etc
Beautiful truck but ditch the Boost Autoparts hacky scotch locked patch.  I couldn't do it
Grab a WAMS/BT Diesel and program it in instead.. my 2 cents
Thank you!
