The latch broke on my glove box door so I ordered a new door. I attempted to remove the old door to install the new one. I removed the 3 hinge screws at the bottom of the old box and encountered 2 tethered bolts still holding the old box hinge to a plastic strip and is part of the paneling. I need advice on how I can remove these two hinge bolt attachments without damaging the plastic strip they are tethered to in order to completely detach the old box and install the new one.
Edited by ChrisTX74
I could be way off on this but the first thing that comes to mind for me is drill them out......possibly??  I think I would check with a body shop before I did that.  If that in fact turns out to be the answer it should drill out pretty easy.  You could use a dremel tool drill bit too; thats an option.  Body shop consultation sounds best to me though.
Edited by Jworks
are you talking about the 2 rivets?  If so just drill them out with any old drill, using a 1/4 drill bit until the head is gone and only the shaft is what you see.  Then take a punch and hammer and tap them till they push through.
Those aren't bolts...they're rivets.  Like sharpz said, you'll have to drill them out (shouldn't be too bad; they're probably soft steel or aluminum)
Thanks everyone for the feedback. I used a 1/4 drill bit and removing the rivets took less than a minute. New box has now been installed.
