So i just heard back from the dealer about my single popping on the passenger side (other post here about that issue
I would like to lift the front of the truck safely so that both wheels are off the ground so that the steering can be turned easily to watch the suspension parts move and see if there is anything else going on. One issue they called out was that the ABS sensor/wiring is what is causing my park assist and stabilatrak issues because of the lift/ how it was run on the control arm. I have 1 floor jack and tons of jack stands, but mostly looking for where under the front end is it safe to support it and not be concerned while im under there. It will only be turned on for a few seconds to watch the components move from left to right and have the wheels off.
OR should i just torque everything down and test if its resolved?
I lift each side from under the rear of the front doors.  Jack stand goes up toward the front of the same doors where the frame is beefed up before it narrows inward.
Watch out if your frame has the anti-rust waxy coating.  Can be a bit slick.
Yea i just want to safely lift it high enough to get off the ground, pull the tire off and turn on the truck and turn the steering freely to check the suspension as well as re-torque everything without the truck weight.
Man one piece of advice, try the spring thing. It’s like 30 bucks and my symptoms were the same as yours. I took the entire front end apart and back together, thought no way the sound was in back. I went crazy trying to figure out the case.
the issue with the leaf spring in rear was transferring all the way to my feet. Sounded like the sound was right in front.
if it doesn’t solve the issue, at least it was a cheap and quick try.
Edited by RPaul
what spring fix are you referring to? Is it the leaf spring clamps? I never installed any after the lift and i did do the "add a leaf" then. But worth a try.. the odd thing is that after the dealership said they wouldnt work on it, the noise has gone away, so im still going to check all torque and look into the rear spring clamps..(if thats what you refer to)
The product called spring things. It’s a flat rubber insert that goes between two leaf springs on rear. They make contact otherwise and caused noise. Mine sounded like popping in front end when turning at slow speeds. Never heard it going fast or straight. Really weird but fixed probkem
https://www.spring-things.com/
I will be checking them out.. thanks..
    ShowMeShooter1332
    ShowMeShooter1332
  • Who's Online   1 Member, 0 Anonymous, 6,762 Guests (See full list)
    • I was around and remember that era very well, so I'm calling b/s on that statement. If they were that bad no police department or taxi company would've bought a single one ... but they were used in both services (and fire) for DECADES. They were bulletproof and proven. Even the early 21st century ones weren't too bad! The early models were legendary.   Mine is proof, but people like atlas are blinded by agenda and refuse to believe facts right before their very eyes.   Even decades after they were built, a new generation started driving them, posting all their builds and shenanigans on Grandmarq.net and Crownvic.net. The failures would show up then, since they all were deep past 100k-150k miles by that point, and younger drivers tend to be a little aggressive, especially with vehicles than can lay a one-tire fire for as long as you hold your foot in it. They've more than proven themselves over the decades.   The only thing that'll really take them out is road salt. The bodies and sheet metal were garbage. A victim of the cheapout FoMoCo and GM have been partaking in before then, and since.   Today it's the stuff that counts - the undercarriage that rots away first!    GMs Caprice was no slouch either. Reliable as a stone ax - the opposite of what they build now.
    • Let me know how your vehicles do in 10 years. You don't know ******, kid. 😂    There's a reason that Panther platform was used as police, fire, and taxi service for DECADES ... long before you were born, apparently.
    • If your connector also has a big lever to get the connector on and off, you don't want to force the lever either way, as it becomes a bigger problem if you bust the lever or the mechanism it works.
    • It's just useful to disconnect the battery to prevent odd shorting out when unplugging/plugging stuff together.  I also  touch the two cable ends together (after disonnecting) to drain the small amount of stored battery energy in various modules.   I believe the main system where you need to be more concerned with, so you need to do the above and then wait some time, iss when you are working on the air bag system, to prevent inadvertent firing of the air bags.   The in-cab switches are just that, plain switches, it's generally not a problem to swap them in/out.  For my '12, I'll get an error message on the dash if I power up the truck w them unplugged, but that's it (power up= turn the ignition on).   The ITBC located above the spare tire is a computer that manages the trailer brake system.  That is probably more important to have the battery disconnected.  It does have to be programmed to the truck, either before or after it's installed, for it to work.  For my '12, I had a very hard time reinstalling the main connector to it (IDK if yours is the same or not), it turned out the silicon seal was jamming up, preventing it from going on all the way.  I finally got it fully installed by lubing the seal with a bit of dielectric grease, then it slid on and latched in place easily.
    • JR ! I just got the truck back from the Dealership today . The technician did a cold remote start on the truck this morning and it made the noise . It was determined that it was a starter issue and replaced it under warranty . Of course   it did not make the sound after a new starter was put in because the truck was not cold . We will we see what happens tomorrow morning when I start the truck cold  . Keep tuned !   Oh I found a video on YouTube of a cold start and it did the same thing your truck and mine do , I will see if I can find it and post it up
