Repost from the general troubleshooting board, they recommended I come over here...
2014 LT Z71 with 4.3.
When the cylinder deactivation kicks in and the truck switches into V4 mode, it has a very noticeable vibration or shake.  Not unlike driving on a washboard road.  This is not a wheel balance / driveline issue, it's definitely when the cylinders are deactivated and it's pretty much like a light switch.  Anytime, any speed, the truck is in V4 it's shaking.  Engine is totally smooth in V6 mode with all cylinders firing.
The shaking occurs the entire time the truck is running in V4 mode, NOT as it transitions in and out of it (as most of the other guys seem to have indicated).  The entire time the truck is in V4 mode, it feels like it's driving on a washboard road at all speeds and under all driving conditions.  V6 is perfect.
DIsclaimer: I "inherited" the truck from my dad, who swears it never had any vibration, but I felt it driving the truck home from his house for the first time.  My dad also doesn't know how to put gas in his own car, and is the sort of person who goes into a dealership and says, "I would like one car, please."
Thanks,
Darel
Sounds to me like one of the AFM lifters have failed. I'm not familiar with the V6 AFM system, but I'm certain it's the same failure prone crap from the V8's. There's also the possibility that it's overdue for an oil change, and/or the wrong oil was used, the VLOM (valve lifter oil manifold) failed, or there's an electrical issue that's not allowing oil to the lifter when commanded.
Usually they fail unlocked, where there's a constant misfire at all times. Sounds like these have failed in the locked position. That's new to me, but this is good news for you - I would just buy a Range AFM Disabler, plug it in to your data link connector (where scan tools plug in) under the dash, and go about life normally with a normal V6. That would be your cheapest possible option.
EDIT: I may have the locked vs. unlocked symptoms backwards. Stupid system! I can't keep GM's engineering straight, and neither can they ...
I don't have any experience with '13-up models, so GM could have changed something in the lifter's design from the prior generation, but didn't fix the problem, of course - I expect nothing less.
Edited by Jsdirt
disregard ...
Edited by Jsdirt
Thanks.  I'm not interested in masking a problem, so I'll fix it one way or another...besides I like the gas mileage I get and my '07 with AFM has been flawless for 200,000 miles now.  I'll start out with an oil change and see how things progress.
Anyone know anything about some sort of exhaust damper the dealers were trying a while back?
You won't notice a difference in mileage. I've been running mine for 40k+ miles and mileage is exactly the same. Of course, if you run it in AFM mode alot, then maybe you will.
I'm amazed you got that many miles before failure. Guess they tried to improve the design, but, fell short as usual. The V8's of the earlier gen failed between 90k-130k miles. I'm waiting for mine to check out at 113k now ...
Just be prepared - you're going to have a big bill to fix this if it is the lifters that failed. The way they designed these engines requires ALOT of labor to access them.
Edited by Jsdirt
Yeah the '07 is around 200k and no issues at all (other than the rear fenders falling off).  The '14 only has 40k and shakes like a leaf.  Supposedly the earlier GMT900s were fine (like mine) but then they changed something that kinda ruined the system. I had a boss with a '13 that burned 2 quarts every 500 miles until he programmed it out.
Thanks,
Darel
Does it occur at 1200-1400rpm so lets say at low speeds, and then say 45-50mph?
If so expand and read below:
Quote
#PIP5228D: Vibration During Active Fuel Management V4 Mode Operation 1200 – 1400 Engine RPM - (Mar 16, 2017)
Subject: Vibration During Active Fuel Management V4 Mode Operation 1200 – 1400 Engine RPM
Chevrolet
Silverado
2014-2017
4.3L LV3
GMC
Sierra
2014-2017
4.3L LV3
Supersession Statement
This PI was superseded to update Parts and Warranty. Please discard PIP5228B.
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern
Some customers may comment about a vibration that is felt between 1200 – 1400 engine RPM when in active fuel management V4 mode.
A drone or resonance may also accompany this vibration.
The vibration may occur at different vehicle speeds but the engine speed will be in the 1200-1400 RPM range.
This vibration does not occur in V6 mode
Recommendation/Instructions
The technician should evaluate the vehicle under the conditions the customer duplicates the concern. Once the concern is duplicated, use vibration analysis tool CH 51450-NVH Pico Oscilloscope Diagnostic Kit (w/NVH) to measure the frequency of the vibration. If the measured vibration is not 21-25 Hertz (HZ), first order engine, use normal vibration diagnostics to isolate the source of the vibration.  If the measured vibration is 21-25 Hertz (HZ), first order engine, install the exhaust damper per the instructions below. If this does not reduce the vibration, follow the three-way catalytic converter and cab mount settling procedures below.
Install Exhaust Damper
Installation of an exhaust damper reduces the exhaust vibrations associated when the engine changes from V6 to V4 mode during AFM (Active Fuel Management). Installation location and position is critical to the performance of the damper.
The damper will be located on the passenger side exhaust pipe, directly above the transmission cross member.  It should be located on the inboard side of the exhaust directly in front of the resonator. It should be mounted so that the damper is horizontal with the clamp positioned as shone in the pictures below.
Important: The exhaust clamp should be positioned so that is will not contact the heat shield above or the frame rail below.
Three-Way Catalytic Converter Assembly Settling Procedure
Note: Do NOT replace the three-way catalytic converter assembly unless it is physically damaged.
Loosen the six nuts that fasten the three-way catalytic converter assembly to the exhaust manifolds.
Remove and replace the exhaust muffler clamp that joins the three-way catalytic converter assembly to the pipe of the muffler assembly.
Note: This is a special clamp called a Norma clamp and it must be replaced as it is a one time use clamp.
Reinstall the three-way catalytic converter assembly following the specific tightening sequence and fastener torque specifications found in SI.
Cab Mount Settling Procedure
Warning: When settling the body cushions, do NOT separate the frame from the body more than is necessary. Possible personal injury and damage to multiple parts may result if you do not follow the guides outlined below:
Intermediate steering shaft—Do not allow the shaft to extend more than 25 mm (1 in).
Fuel tank filler hose—Do not stretch the hose excessively.
Tail/Turn signal lamp wiring/rear lamps junction block—Leave slack in the wires
Park brake cable—Leave slack in the cable.
Body ground straps—Leave slack in the wire.>>>>>
The technician should first loosen the fastener located at the center of each body mount (6 for a regular cab, 8 for crew and double cab).
Using a large angled pry bar, lift up the cab body slightly to settle / relax it. Perform this at each mount location one at a time.
Repeat this cab mount settling process twice, to confirm the mounts are settled / relaxed.
Visually verify that the cab to box alignment is correct before re-torqueing  all mounts to specification found in Service Information, body repair, frame and under body section.
The cab / body mount position locations
The numbers in the picture below indicate the specific mount position.  The mounts on the passenger side of the vehicle are identified the same way. This will assist the technician to identify the correct location of each mount so they can be torque to the proper specification.
In short, loosen and re-set the cat Y pipe and install a vibration damper on the end of the Y pipe, maybe check the cab mounts.
Edited by newdude
That would be nice if that's what it is. Cheap and easy - can do that yourself in the driveway.
Thanks, I had found this bulletin before, but it doesn't list a part number for the dampener.  Do you happen to know what it is?  Also looking on sites like GMPartsdirect doesn't show anything in the explodeds.
It does it all the time, 100% of the time every time in AFM, regardless of engine or road speed.  V4 = shake, V6 = no shake.
Huh? So much unbacked up assumptions. So if a small percentage of trucks have AFM issues they all do regardless of the years and it sounds like you say they all fail before 130k or it is an anomality if they don't? Then you go on to say it won't change your gas mileage unless it is running in 4 cylinder mode which is exactly when it saves fuel and raises your gas mileage...Shesh, so basically it works as advertised and as independent testing has showed saves fuel and it has a low failure rate which is on par with anything that built by humans and machines made up of thousands of parts sold in mass quantities. Thanks! We got some good unbiased info there!
We understand some people get burned by a failure or don't like something new such as AFM, a turbo four cylinder or auto start stop; but then they have to come in every thread and talk about how bad they think it is in their eyes which doesn't help and is completely unrealistic from reality.
Tyler
84090482
Exhaust Damper
15748648
Exhaust Clamp
20779889
Clamp, Exhaust Pipe
Tyler
Just telling like I see it. This is what I see. Since you have all the answers, why aren't you helping people in this forum? Why do I seem to be the only one that attempts to help people in here?
I saw ZERO fuel mileage change with AFM disabled. So ... you're going to tell  me I'm wrong? LOL! You're pretty f'in funny.
Edited by Jsdirt
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
    • I had an alternator fail that was shorted internally in such a direct fashion in addition to the larger gauge cables that it appeared like a VERY dead battery. Granted I think the car did power up, it definitely wouldn't start.   Rodent damage to wiring?
    • ... I don't think he could.
    • Using experience to justify bad advice is lazy and typical of someone incapable of articulating why their advice is prudent.    This immediately sets off the BS alert and the advice that followed certainly qualified.   Asking an idiot for help getting out of dumb situations because he is an expert... at getting himself into dumb situations.   Unless I've been living in an alternate universe - the first thing everyone does when getting into a sticky situation is shift to a higher gear 🤨.   Of course not, the torque multiplication, mechanical advantage and finer control typically afforded by the lower gear is far better suited for this scenario.   There ARE scenarios where a higher gear MIGHT be appropriate determined more by the drivers ability to control EXCESSIVE wheel spin versus applying torque to the ground.
    • I'm not sure I agree with "extreme" low speed, high torque sentiment here with regards to the prescribed use of low range. How about...whenever it's needed?   A 2.72:1 transfer case and whatever differential gears these Silverados have (3.42's, maybe?) aren't producing "extremely" low crawl speeds. Or insanely high torque multiplication. Even with the 1st gear in these newer transmissions. But it does provide mechanical advantage and potentially better control at slower speeds. And with extra weight or towing, I think it adds mechanical sympathy for the truck as well.   Plus, traction control and the other assists generally turn off when you shift into low range. Those aren't needed here, they'll work against you if you need wheel spin. In high range you'll need to figure out how to turn off the various modes those assists provide. Depending on the vehicle, those things don't all automatically turn off or turn completely off.   While I agree that a farmer might have some great practical experience, a recommendation to "always" using one gear isn't very informed advice. If the farmer had said WHY and could explain the physics behind his prescriptive "always" I'd definitely listen. The way he's described here makes it sounds like he could either be uninformed or is telling everyone what worked for him, not necessarily that there could be a more advantageous way about things.
