So i finally pulled the trigger and installed a light bar on my 2019 Trailboss. I wanted a bumper mount, but refused to drill holes. SoAfter looking all over ZROADZ was the only mounting option i could find.
So I bought these ZROADZ mounts
  https://zroadz.com/i-23909931-2019-2021-chevrolet-silverado-1500-front-bumper-top-led-bracket-to-mount-30-inch-curved-led-light-bar-pn-z322282.html#!submodel%3DLT TRAIL BOSS||model%3DSILVERADO 1500||make%3DCHEVROLET||year%3D2019
and this Rough Country 30” Curved bar light.
https://www.roughcountry.com/30-inch-curved-led-light-bar-72930blkdrl.html
The install for the mounts and light was very easy. the ZROADZ link above has a pdf with installation instructions, but it mounts to the bumper mounting bolts. The Rough Country light bar has a very high quality wiring harness and i didn’t want to mess with that and shorten it up, so the excess is taped and hidden behind the fender. There is an accessory “port” where the trucks wiring goes through the firewall, so getting wires through was a cake walk. Just cut the end of the rubber piece off. I took the switch plug aport pushed it through and put plug back on. There is a black plastic mounting box for one of the vehicle control modules you will have to remove to reach the wire on the inside. It is held on with two nuts and comes off easily. I ran the switch wiring behind the console and up through steering column. Its a temporary location until i can find a good solution. I would really like to use one of the blanks in the center console. The light bar itself is crazy bright and can’t believe i went this long without it.
My only complaint and its me being picky, is that the light bar sticks out a bit further that i had hoped. And that is only because the RC light bar is no where near as deep as others i have seen. Its about an inch shallower than the light bars on my ATV. If it was like other light bars, you probably wouldn’t even notice.
I wanted to post a bunch of images to show the install, but it only allows a few so here is a link to a google photos album.
https://photos.app.goo.gl/eKYFVvY9ij9ZnDfEA
I hope this helps, if anyone has a questions or wants other pics. Let me know.
  • Thanks 1
    • This is a really late reply but I just found this thread. They won't sell the hinges. I've gone 7 rounds with them. Their solution is to buy a new cover. I'm about to buy a new cover and it won't be a Bakflip. It also won't be from realtruck.com.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
