3 hours ago, The_DJH said:
Great post, I'll swap mine over from yellow and yellow/black and see how it is.  Do i need to change the fuse or anything?
I didn't change any fuse, I haven't seen any issues.
  • 1 month later...
I have a 2026 LT Trail Boss with Bose. I am very confused trying to install the GM/Kicker under seat subwoofer kit.  The directions want you to tap the yellow/yellow black wire for the front speaker for high level inputs.  I do not want to follow those as I want to grab the tap at the Bose amplifier since I don't want to mess up the factory wiring.
I picked up a T-harness from Soundgoodstereo that plugs into the 8 pin connector at the amp, I believe x1.  This thread started of recommending that.  Now question related to this harness, it has four sub wires.  I assume one set positive and one set negative. The Kicker amp is only looking for one negative and one positive.  Do I just use one set on this harness or do I two positive into one positive and two negative into one positive?
Now if I want to use the specified wires in the instructions, is there a T-harness for that?
If I could get both then I could test and see which I like better without tapping.
Finally is there a place I can get an updated Bose amp pin out diagram?  This install should not be as hard as I am making it.  Any advice is appreciated.
Oh, I will be using the Kicker bass adjust knob.
Use one set of positive and negative into the Kicker.
This should work for the other amp plugs and has the pinouts for you. A little overkill to get the what you're looking for, but could be worse.
https://soundsgoodstereo.com/products/pac-aph-gm02-speaker-connection-harness?srsltid=AfmBOoqQWjVsP3WLybAeokKKOHra_E-7RZI_mQSND2dzOqgFDo2xs6Q9
I started my install this weekend. Everything was pretty straight forward but I ran into one issue with running power through the firewall. The nipple grommet on my High Country already has a small harness running through it - has anyone else ran into this issue? And on the engine bay side, does the wire basically just penetrate the factory wiring boot? I did this on my '22 Trail Boss and it seems much easier but thats been a few years. My other thought would be possibly drilling a new hole adding a rubber grommet just to the lower left of the factory hole. Thoughts?
Has anyone used a T-harness off the Bose amp and obtained power from there? It seems a little odd that such a small amp needs 3 power leads
    Greg3160
    Greg3160
  • Who's Online   2 Members, 0 Anonymous, 418 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
