Anyone using the OBDLink MX+ device on their 2019+ truck?   Never had an OBD2 reader/scan tool.  The MX+ seem to be the best value for the money.  Only reads DTC codes for now.  All the advance diagnostic info isn’t available for the 2019+ yet.   Seems like I can’t find any OBD2 reader or scan tool to read ABS and SRS codes for our trucks.   Don’t need a reader/scan tool, just want one.
