Looking for creative/unique ideas for removing back seat on my 2018 extended cab to better accommodate my 2 large dogs. I've seen some have built plywood platforms and covered in marine carpet, which I like. But curious if anyone else has done something similar and if you had any suggestions. Thanks!
I have a 2015 Sierra, I didn't pull the seats I just folded them up and built a platform like you mentioned. I have. two large Golden Retrievers and they have plenty of space. When we need the backseats for more people I just pull the platform and fold the seats back down. This system works great for me, its the third platform I've built for my dogs over the years. I built mine out. of 1/2" plywood covered it with 1" foam then installed outdoor carpet.They seem  pretty comfortable on long trips.
I stoped letting the dog in the back seat area, the claws and dirt are too destructive to the interior .. I instead bought a camper shell , this is his pig pen area, his water is back there, and i installed the BedRug so its soft on his body. get a shell with side sliding windows , lots of airflow and he can hang his head outside safely.
    • 3.19 @ Kroger’s in Montgomery Tx
    • We have now!  2027 GMC Sierra  Early look, but I'm a GMC guy and so far I think I like the looks of the Chevy better.
