I bought a used trailer and put all new lights wires and breaks on it. I hooked up the breaks last weekend and they were all humming nice and loud. I took it for a test ride and turned the gain all the way up because I wasn't feeling much braking. Right rear wheel locked up on gravel but the others kept spinning. I thought maybe grease got through the seals and buttered up the brakes on the others but this weekend I took apart the front left and it all looked good. I put it all back together and now I don't get any hum on anything except for when the override is squeezed. Looking at the dash it says trailer brakes connected. I can change the gain but the indicators don't light up when I step on the brake. I checked the fuse and it's good. I jammed a snow brush between the seat and peddle and tested the junction box and I only have a reading of 0.5 on average it fluctuates. It never hits one volt. Anyone have any ideas?
First thing I'd try is hooking your truck up to another trailer known to have a properly functioning brake system and see if you can determine if it's a tow vehicle issue of a trailer issue.
Okay, I found a friend with a trailer and the truck is fine. It's probably the scotch locks I used. I will redo the wire connections.
I'd be soldering all wiring connections and covering them with heat shrink tubing if it was me.
    iso221
    iso221
  • Who's Online   6 Members, 0 Anonymous, 586 Guests (See full list)
